Acoustic Horn Design – The Easy Way (Ath4)
My previous question regarding the frd data in ABEC was related to "designing out" the dip in response of the HF146 instead of using filters. Does this hold any merit?
That was measured in some particular horn. Your case may be very different. It's not trivial to tell what is caused by the driver itself, i.e. what will always be there (more or less). With exceptions, that is usualy break-up related and not quite in this frequency range.
FWIW, the response provided by FaitalPRO for the HF142 shows a similar dip, but the dip is not present in the measurements here: Test Bench: FaitalPRO HF142 Compression Driver Coupled with LTH142 60degx50deg Horn | audioXpress. The horn is supposedly the same (LTH142), so I'm not sure why the two curves differ so much.
limacon, are you new to diy? You seem to be a quick learner 😉
If you haven't already read it, this thread might be of interest.
Particularly Nate Hansen's and Augerpro's replies on page 2 are insightful.
Always held a strong audio interest along with electronic engineering. I own a company that historically has manufactured domestic stair lift upholstery. In the last few years we have moved into aerospace cabin interiors and in doing so built up quite the pocket battleship with onsite tool making, cnc machines and foam injection technologies. Which in turn lends itself to this thread.
1/12th smoothing. On axis (red), and then approx every 15 deg. Will be more scientific about it tomorrow with better room treatment. I'm also making a foam covered MDF rig for the UMIK stand so I can set more precisely at 7.5 deg intervals.
Tools used
UCA202 - NwAvGuy: Behringer DAC Modifications
EV DC ONE (analogue for now but looking for AES option)
MC2 T4-250
UMIK-1
REW
For impedance I use LIMP from ARTA package (could be used virtually for everything): ARTA Download
Room treatment is irrelevant once measured gated. For that you need to see impulse response and limit that to the time before the first reflection arrives. Usually then there is no need to smooth it further but 1/12 (or more) should make no harm either for the purpose of crossover design. I have no experience with REW. For all frequency response measurement I stil use HOLMImpulse, which is extremely intuitive in this regard.
BTW, the results look very promising so far.
Thanks. I'll look into that. Added gating. 1/6 , 1/12 , 1/48 attached.
I've seen a few horns droop at 1K to 2K with the HF146. What part of the cd/horn/baffle geometry could this be related to? If any.
Will compare to XT1464 also.
This is strange, doesn't look right to me. I doubt it represents the anechoic behaviour. I would expect it to be pretty smooth at least up to 3 kHz (and flat between 1 - 3 kHz), I see no reason for the responses shown.
- If this was a correct measurement, something would be wrong anyway.
BTW, for anyone trying for something rectangular, I would recommend to start with this set of parameters (maybe SEExp could be lowered), which already proved to work exceptionally well, even in several diferent sizes:
Code:
ThroatDiameter = 25.4             ; [mm]
ThroatAngle = 27                  ; [deg]
Coverage_Horizontal = 85         ; [deg]
Coverage_Vertical = 85            ; [deg]
Depth = 95                          ; [mm]
Depth.ConicSectionPart = 0.2
Shape = raw2rect
Shape.FixedPart = 0.2
Shape.CornerRadius = 35.0        ; [mm]
SEExp = 8
Total width x height = 260 x 260 mm (10.2 x 10.2")
It was here before: Acoustic Horn Design – The Easy Way (Ath4)
It should be easy enough to adapt the parameters to fit whatever size required - change the depth or coverage angle(s).
And again, this is the latest (still unofficial) release: http://www.at-horns.eu/release/ath4x.zip
Doesn't look much different from other measurements of the 1.4 Faital drivers with Ketone Polymer dia.
Nearly all of these show some variation in the response, often with a dip >2k.
3 plots of a HF144 (16 Ohm) + 18Sound XR1496. The first is a quick and dirty (raw) response and the second and third with 6 PEQs applied.
  • 00_faital-hf144-16ohms_18sounds-xr1496_1m_indoor_4v_4.2ms-gating_6-eq_no-filter_freq-response.png
  • 01_faital-hf144-16ohms_18sounds-xr1496_1m_indoor_4v_4.2ms-gating_6-eq_no-filter_distorsions.png
We need reliable anechoic polar data masured at sufficient distance. The bumps in 1 - 3 kHz range are hardly caused by the driver which is too small to cause such phenomenon. There is obviously some diffracted or reflected sound coming along. Let's wait for another attempt for measurement. Maybe a photo of the measurement setup would help here. For all horns I ever measured this was the least problematic frequency range which really should go smoothly without a glitch (it may still need an equalization but that is not the issue - that's not even possible here).
