As many inputs as you want, depending on the input switch you use... If you look at my built I used 6l6s / Jim's small but efficient 3 input switch.
I believe the ready to build kit comes with a 2 input swich, but better check...
Claude
Claude
I drive F4 with B1K on 105dB speakers and seldom go more than mid on the volume knob.
It is really good.
It is really good.
I replaced the heater resistors with 510s to lower the level to exactly .6vdc. Still getting channel imbalance at output. 2.3v L and 2.1v R. Input buffer at source of Q1 is 356.5 mV L and 364.7mV R. Input at Nutube is identical, and output at tube is off....2.3v L and 2.1v R. I didn't yet check the voltages at the F pins on the tube but I have reflowed everything twice so far. I guess I have a bad tube?
I am going to check the plate resistors tonight, but if they measure identically and DC voltage at the supply side of them is the same...I have to assume something is wrong with the Nutube itself. Since it does sound OK otherwise, clean and quiet, can I change the plate resistor on one channel to compensate? Should I lower the R or raise the L channel to re-balance my output voltage? How do I determine what the right value should be?
Hi Vince,
The gain is reasonably high (16dB?) , but the voltage swing won't drive the F4
to full output. Also, the distortion starts to get a bit high above a couple volts output.
Definitely something fun to try if you can get by with just a few watts.
Dennis
Dennis
We’ve ruled out the JFETs, and R1?
Identical input voltages (in AC) can be measured at each component from input jacks to the Grid pins of the Nutube. (with volume wide open). Changing the DC grid bias makes no difference in output AC voltage. Output voltages (in AC) are off from the A pins of tube all the way to output. I have swapped the JFETS (and cleaned the pins), R1 (100ohms in my case), the 1K resistors and the output caps between channels and the problem remains in the right channel. I also removed the right side output cap and still exhibit lower voltage. I have reflowed and sometimes added solder to every pin on the board with no change in performance.
I suppose I could lift the output side of the 1K resistor just to make sure; I don't know enough about electronics to know if or how the downstream parts would affect the voltage reading at the plate.
Process of elimination, I don't know what else it could be. LOL, I don't even know why it would be bad, the tube looks perfect. I have been keeping a log of every AC/DC voltage of each component in the system. Tested at 1KHz, max volume from computer and max volume on B1K to keep it consistent. I sure am glad I used euroblocks on this board!! After this experience I am using blocks on every board I build from now on 😉
DIY Audio store should also sell the accessory kit for the NuTube which includes a socket for the tube, to blow easy change-out.
If someone knows what individual socket pins one can purchase to install on the PCB that would accept the pins of the NuTube, that would be appreciated. Of course, this means that some additional stabilization of the NuTube will be mandatory as the pins will raise the NuTube well above the surface of the PCB. Microphony might be a problem....
I was repairing Falcon Acoustics mini monitors (ls3/5a clones) I built for one of my daughters. Hooked the mini monitors up to my F6 and B1 Korg and got the huge and intimate soundstage that my 300b monoblocks provide on my Altec A5. Great sound. Apparently the mini monitors thought they where being driven by powerful SE triodes, while the Altecs are not as easily fooled ( sound great though 🙂 )Thanks Soundhappy. Well triode phase effect, Im not sure, they have a lot of detail but still a smooth and rich sound signature. 3d is good, as far as the Altecs can conwey 3d. They dont however turn my M2 into a 300b amp. I have 300b, pentode driven, monoblocks to compare. Need to try them with other amps. Espesially a rather harsh and overcontrolling class D amp.
Thanks Dennis. Might have to live without this one...for a little while anyway. 😀
socket means pushing in
pushing in means force
force on display type tube pins - means trouble
Claude
Merci Claude, je vais regarder.
OK, I understand. Hope I can get the Korg Accessory kit with the carrier PCB/header lead plug-in, as it is currently out of stock at RS in USA and no-one else in US carries it.
- B1 with Korg Triode
