D-Noizator: a magic active noise canceller to retrofit & upgrade any 317-based VReg
Please read my posts 🙂 in the he schematic to the left, the connection between the Elvee/Diego network and the 220uF has been cut, and it still sims exactly the same way as when it isn't cut. This leads me to believe that simming with this LM317 model is not useful for our purposes. If I made a mistake, please tell me what.
Would a MOSFET capacitance multiplier followed by an LM317 not be orders of magnitude better than a De-Noisifier.
Say 60dB for a typical cap-mult, + 75dB for a SOTA 317 =135dB.
That's better than a plain vanilla denoiser, but comparable to a Dienoiser or a Nonoiser, without an additional power component in series wasting several volts
Why has nobody performed a transient response by switching a fast load change. I bet the results would look awful.
I did, and it remains generally well behaved thanks to its low impedance, but if the peak to peak amplitude of the transient exceeds the average DC output current, the correction circuit is overwhelmed, altering the DC output, etc.
For a regulator intended for accurate, low noise application, such a limitation is not really a problem.
But first let me address the following: I don't think the LTSpice sims work like everybody thinks. Try this:View attachment 806094
The connection between Q6 and C10/12 has been cut. However, it sims just like the version with the connection made. Wierd. The only thing I can come up with is that the network can also work as a shunt between the two power lines, and that this is what the sims show.
However, in my test fixture, cutting this connection has a huge effect.
So, my question to y'all is: did I do something wrong here, and if not, what is going on?
In the asc you posted, the outputs of the regulators with and without the denoiser are labelled with the same name: out.
For LTspice, this means that they constitute a single node, ie. they are shorted.
When you unshort them by using different names, things become normal:
attachment.php
With a 100ns resolution, everything looks normal: there is a visible residue for the regular 317, which is normal, and nothing is visible for the Dienoiser, which is normal too: in transient mode, the tolerance, digit number and resolution should probably need to be increased to see something.
There is no sign of instability, but the sim is not fully reliable for that: one needs to make a physical test to confirm it, which I did
I use them for a power amp frontend within a cramped case and selfmade adapter boards. Used other LM317 implementations for this before (standard and with tracking pre-reg) and would like to test this one. The amp is a NCC220 from avondale.
With the denoizer on, the noise climbs to .12 uV, but it must be even lower in a well shielded setup. I can see the sort of variations in the noise voltages, .12 was the maximum. And it reacts to presence of a hand or finger like a Theramin, it is very sensitive to EMI. In short, shielding will be important to get the best results.
Very interesting!!!
A difference of more than 55 dB compared to the regulator alone (without bypass capacitor)!!!.
Could you repeat the measurement by short-circuiting the resistor between base and emitter of the BC560C?
That measurement could help to see the typical differences between the denoiser and the dienoiser.
Best regards
