Babelfish M25, SissySIT - general building tips and tricks
Joined 2018
I am re-biasing SissySIT #1 after fixing snubbers. I also made a change to eyes on SIT connection. Amp is behaving much better. Was it my power supply or a suboptimal connection to SIY?
Official Court Jester
Joined 2003
-remove plastic drek ; easy if you heat it shortly with heat gun , set to mid temp
-usually it's needed to cut solder connection on upper side of lug with cutters (pliers) so you can squeeze wire properly - each half independently
-solder it properly
-place heatshrink tube of appropriate color and dress it with heatgun
-that's proper connection
The sissy sure likes to creep up. I thought it was set at 1.8A @ 52*C and in 3 hours 2.1A @ 56*C. The Laser gun is sure helpful for ”sissysiting”, is this a thing now? :rofl:
I have no clue on why R18 value was wrong. I was supposed to order the proper value resistor with 7805 and then after 6 month delay things went sideways like Wiley on a rocket. :yikes:
Sound is very pleasing with Jensen, very detailed with wonderful tone and presentation. Thankyou ZenMod, Papa, DiyAudio crew.
It’s a keeper! :up:
Now that Sissy is giving M2 a break, I might have to rebuild it with X boards for more sound options.
Joined 2003
-solder it properly
I thought I was alone in this process! Grab eye with old heavy needlenose, hold in flame of gas stove (in my case) scrape off plastic bit. crush and solder covering with shrink wrap.
And I just thought I was OCD here...
Russellc
So I am also not alone with the Iq creep. I can't bias or offset the right channel whereas the left is done (or that's what I think it is). The only way to keep the right channel Iq from creeping up is to take the chassis lid off. Does anyone else observe the same?
It would seem to me that you might have a situation where you have constant voltages at the gates of the mosfets and one or both of the hall sensors aren't operating correctly.
If both channels have the same mosfets, then both channels should behave the same.
Please don't tell me you bought your mosfets off ebay. :rofl:
It wouldn't hurt to check every resistor value and every soldered joint on the board.
Thermistors might just be bandaiding a problem that shouldn't be there in the first place.
If you need thermistors then it kind of defeats the purpose of having the hall sensor in the first place.
I would work my butt off to find the root cause of the problem and fix it.
It's a shame to have to resort to thermistors. I don't even use them on devices like those specified here with constant voltage bias circuits.
Joined 2016
I have the upward creep of Iq in my SissySIT as well. I have traced it to two sources:
- temperature: as the temperature of the heatsinks and therefore the devices rises, the Iq creeps up. I have a 5U/400 case with its high thermal mass, and therefore the temperature-related "upcreep" of Iq continues for a few hours, and eventually levels out.
- Rails voltage: At my house, the wall AC voltage is rather variable (220-230V), and often rises in the evening. Rails voltage varies accordingly with wall AC voltage in ... Iq in the SissySIT is strongly dependent on rails voltage, and so also rises with rising rails.
Because the DC offset is dependent on Iq, I have tried to set my SissySIT to zero DC output offset at some intermediate rails voltage (DC offset zeroed for about 225V wall voltage in my case). That way, it usually only varies between -/+ 50 mV in the course of an evening.
The opto bias scheme has a harder time in keeping the bias current constant than, for example, in the M2 - this is because of the combination of an enhancement and a depletion device in the SissySIT, where the Delta Vgs (between N and P device) vs. Iq varies much less than in the case of N and P both enhancement devices, where the Vgs's nicely spread apart with rising Iq.
I've talked with Zen Mod about this at this year's BAF, and the solution we came up with at that time was to just bias the SissySIT more conservatively, so that it levels out where you want it to be :).
I have tracked the total current draw of my SissySIT with an energy meter. The total draw for the amp levels out at around 230W, usually. (the label on the Y-axis is not correct - it should be W). Amp is not in constant use at the moment; the next time I open the amp, I will adjust bias down some more.
attachment.php
Regards, Claas
