Thank you Prasi.
Can you please advise on soldering the TH LT4320 directly on to the PCB vs using a socket?
I was looking up DIP 2 row 8 pin socket and saw the amp rating was only 1A. Wouldn't that be too low for the LT4320?
LT4320 is just gate controller and doesnt need high amperage.
All high current flow happens between source and drain of mosfets.
Socket makes it easy to remove and replace the chip if required in future.
Believe me, replacing an DIP IC soldered directly to PCB is PIA without proper tools and support of another person.
SMD and THT rectifier only boards
tomtest: SMD: 10 pairs, THT 5 Pairs
wgh52: SMD 18 pairs, THT 16 pairs
randytsuch = SMD 2 pairs , THT 3 pairs
alazira: THT 6 pairs
grufti = SMD 4 pairs
Destroyer OS THT= 4 PAIRS
Total : 34 pairs SMD , 34 pairs THT
LT4320 based CRC PSU PCBs
vvs07 = 4 nos.
randytsuch = 2 nos.
tubesguy = 2 nos.
windwardmt = 4 nos.
alazira = 2 nos
grufti = 2 nos
total 16 nos.
vvs07 = 4 nos.
randytsuch = 2 nos.
tubesguy = 2 nos.
windwardmt = 4 nos.
alazira = 2 nos
grufti = 2 nos
total 16 nos.
Prasi,
Very helpful - thank you for the guidance.
For MOSFET, will probably go for IPP040N06NAKSA1, one of choices listed by danny_66:
LT4320 based active rectifier
Thank you Prasi.
Hi Zman,
I use dip8 sockets for all my LT4320 based psu’s. Reason being is the are pricey little fellas at $10 a piece. I can remove them from inactive components and install them into the currently used component. Doing this, I really only need 6 LT4320’s. But you must be very careful with removal/install and it does get to be a PITA
Sometimes my ‘frugal-ness’ gets the better of me, LOL!
I understood that the snubbers were still being recommended
Of course they are, people love repeating mantras I see no spikes at all on the scope with the 4320, yet have issues using these rectifiers in very low noise applications.
For some reason there are several commercial/gb threads on the 4320 running atm but not even one where the operation specifics are being discussed. Says lots about general diyers mentality. Having a technical discussion inside a GB thread is just too annoying.
Prasi,
For now I collect list of probably compatible THT FET's for LT4320.
Maybe you will find some interesting:
Infineon Technologies IPP029N06NAKSA1 (60V, 100A, Vgs(th) 2.1V, RDS(on) 2.7 mOhms, Qg 66 nC)
https://mouser.com/ProductDetail/726-IPP029N06NAKSA1
Infineon Technologies IPP029N06N (60V, 100A, Vgs(th) 2.1V, RDS(on) 2.7 mOhms, Qg 66 nC)
https://mouser.com/ProductDetail/IPP029N06N
Infineon Technologies IPI029N06NAKSA1 (60V, 100A, Vgs(th) 2.1V, RDS(on) 2.7 mOhms, Qg 66 nC)
https://mouser.com/ProductDetail/IPI029N06NAKSA1
Infineon Technologies IPP040N06NAKSA1 (60V, 80A, Vgs(th) 2.1V, RDS(on) 3.6 mOhms, Qg 44 nC)
https://mouser.com/ProductDetail/IPP040N06NAKSA1
ON Semiconductor / Fairchild FDP045N10A-F102 (100V, 120A, Vgs(th) 4V, RDS(on) 3.8 mOhms, Qg 57 nC)
https://mouser.com/ProductDetail/FDP045N10A-F102
ON Semiconductor / Fairchild FDI045N10A-F102 (100V, 120A, Vgs(th) 4V, RDS(on) 3.8 mOhms, Qg 57 nC)
https://mouser.com/ProductDetail/FDI045N10A-F102
So what issues are you having? What are your "low noise applications"? Are they audio related? I assume problems in low-noise applications means you are seeing some kind of noise--could you explain?
Thanks,
Ron
Hello analog_sa,
It's a good info that should have been posted ago.
Mantras are always worth repeating whether you find them useful or not, they give you peace of mind.... Much more important, I dare say. Peace...
Prasi
All assembled and mounted in 4u chassis, delivering a constant 26v (with no load). Just got the Aleph J boards to assemble and test now!
Nice work mpa!
Would you please share the following:
1. Your transformer secondary voltage ratings in VAC
2. Primary (input) voltage spec
3. Mains voltage (if you have measured)
adding wlowes to the list
wlowes - SMD 3 pairs
Total : 37 pairs SMD , 34 pairs THT
vvs07 = 4 nos.
randytsuch = 2 nos.
tubesguy = 2 nos.
windwardmt = 4 nos.
alazira = 2 nos
grufti = 2 nos
total 16 nos.
vvs07 = 4 nos.
randytsuch = 2 nos.
tubesguy = 2 nos.
windwardmt = 4 nos.
alazira = 2 nos
grufti = 2 nos
total 16 nos.
vvs07 = 4 nos.
randytsuch = 2 nos.
tubesguy = 2 nos.
windwardmt = 4 nos.
alazira = 2 nos
grufti = 2 nos
manniraj = 2 nos
total 18 nos.
vvs07 = 4 nos.
randytsuch = 2 nos.
tubesguy = 2 nos.
windwardmt = 4 nos.
alazira = 2 nos
grufti = 2 nos
manniraj = 2 nos
total 18 nos.
vvs07 = 4 nos.
randytsuch = 2 nos.
tubesguy = 2 nos.
windwardmt = 4 nos.
alazira = 2 nos
grufti = 2 nos
manniraj = 2 nos
Marcel S. = 6 nos.
total 24 nos.
vvs07 = 4 nos.
randytsuch = 2 nos.
tubesguy = 2 nos.
windwardmt = 4 nos.
alazira = 2 nos
grufti = 2 nos
manniraj = 2 nos
Marcel S. = 6 nos.
total 24 nos.
- Group Buys
- LT4320 based active rectifier
