The making of: The Two Towers (a 25 driver Full Range line array)
Another possible suspect, simple, clean but again no dimensions:
attachment.php
Monacor offer 10mm acoustic foam, 2 units (MDM-3002) 480-378mm 15,99€ or 2 units (MDM-8602) 611-480mm 24,90€.
Maybe bit borring but one could style it with logo in center and slant or rounded edges.
attachment.php
Looked at another grill from Rockford, it was even bigger.
I guess I could make this previous one work (the ~189 mm), still have to check the JL, but like the Rockford grill better. May need to look at other manufacturers as well (hopefully without logo)
Looks like JL's grill is also bigger than I need, about 295 mm
attachment.php
Is your front panel removable? I can't remember now. If it is you could consider using a fibreglass mesh wrapped around and squeezed in when the panel is tightened back up. Some felt on the edges if you need a little more excursion room. I have got some screens at home made out of pet mesh, extremely strong.
This stuff
LS Product Details
I like that laser cut option 2nd best. Best would be no grill and a serious discussion with the cat🙂 I don't see how you can add a grill w/o compromising the look. Perhaps you can end up with a different, equally good look.
The grills I linked are steel and painted black. Painted to match the cabs and flush mounted I think they might effectively disappear. But I think you would have to CNC cut a small, precise recess for them for this to happen.
I'm leaning towards these:
attachment.php
As these got through the beauty commission here at home 😛. The laser-cuts looked too much like wheel caps in her opinion.
I think I can make them work, without seeing any hardware and still keep the look somewhat similar as planned. I'd prefer them to be naked, but don't want to gamble with the drivers...
I'll see if I can measure my holes as build, I seem to recall some minor adjustments that I've done to the final construction. I think I can set these lower into the round-overs without damaging the look too much. They will still protrude somewhat to keep enough space for the surround.
