JamJar: an HPA-1-inspired power amp
Jeff,
You could replace the mosfet in the VAS with a high beta bipolar (possibly lower distortion) a re-bias and have less of a voltage drop to deal with. The key to the performance to this topology being the cascode. :wiz:
I am not a particularly big fan of mosfets as gain devices but as followers that is another matter entirely.
Jam
Meanwhile back down under...................
You could possibly replace 2sk2013 with a lateral to-220....
Interesting thought. That would nearly halve the rail voltage penalty.
In other developments I could now go back to a BJT CCS instead of the serial JFETS. With the removal of the doubled-up 2SJ109s in the LTP there's little point in 9mA through it, and with 5mA I can get comfortably under a Zetex e-line's max dissipation (280mW vs 800mW for the Zetex derated to 60ºC). The JFETs show less distortion though....
Jeff,
The 2SA970 and its complement that Pico mentioned are excellent devices for use in this application. The beauty of the cascode is that allows you to use this device in this location (limits the voltage swing seen by the device and thermal issues are no longer a problem).
For the cascode my choice would be the KSC2690 and its complement.
The cascode is esentially in grounded base operation so bandwidth and and the introduction of an unwanted pole should not be an issue.
Jam
P.S. If you need any devices please pm me and I will try to get them to you.
I started looking at the Hitachi topology. Here's the baseline, based on the schematic Jam posted:
attachment.php
While it performs well at lower frequencies (aside from a shockingly poor phase margin), it falls apart at higher frequencies (17% THD20K @ 60W).
The VAS current looks really low to me; raising it to 1.8mA appears to fix the high frequency issue (dropping TDH20K to around 1%).
But there's still that scary phase angle. The AC waveform says it should be oscillating at 400kHz (at least the phase angle goes over 180º at that point, and the gain is still way above unity at +10dB). However, if I feed it a 440kHz signal it shows an ugly -- but non-oscillatory -- sine wave.
I can improve the non-existent phase margin by replacing the Miller compensation with a moderate amount (30p) of lead compensation, but the phase margin is still a paltry 20º.
Thoughts?
