3D printing 1/2 of a waveguide
CR10 should be capable, but with its stock hotend and nozzle (0.4mm dia) it would take days to print each half of one.
It's took about 3 days to print mine but am not in a hurry.
I notice the woofer ports look different from the original.
Very nice! What setup? Never get loosy strips?
CR10Spro
PLA by Hatchbox
Nozzle: 200C
Bed:60C
Speed:90mm/s
Fill:30%
Nozzle size 0.4mm
Time print: about 3days
I was surprised that I have no issue with the printer very much set-and-forget. I have Raft support turn on waste little more PLA. It think it's worth it, make the print stick to the bed better. The 2nd 1/2 piece is printing at the moment. Let's see if it's turn out OK.
more pics
2nd half horn done.....yeah 3days.
Are those guides to align piece together?
Look nice overall thank Bill.
I probable built ~2.3cuft enclosure , simple vent alignment, different shape than Bill's.
And will use different CDs as I have those already.
Those aren't guides really, just an artifact of when I was doing the clamping seams or crossover board mounts. Also those tabs at the horn mouth edges facing forward are just to give more bed contact when printing, snip them off. Nice looking print. Any reason you went with such small layer heights? I used 1mm. 1/4 wavelength at 20kHz is 4.3mm.
I am new to 3D, just got the printer about 2.5 weeks. I did print a number of it most came out good so I left as is.
I just ordered a printer that can do
300*300*400mm super large print size; 0.4mm nozzle with ±0.1mm high printing accuracy
What size print nozzles should I use? .04mm work ? I ordered a roll of
WYZworks PLA 1.75mm [ WOOD ] Premium Thermoplastic Polylactic Acid 3D Printer Filament - Dimensional Accuracy +/- 0.05mm 1kg/2.2lb
And for test just regular black PLA for setting it up. I here wood wares out the nozzles pretty fast
And guidance would be greatly appreciated
There is a later version that removes the woofer ports and channels from the horn body. It seems that the woofers should ideally be further out (for better directivity extension), and would probably be better fed out through slots just outside the horn. Mount the woofers inside the cabinet facing toward the sides and feeding out though 'shelf port' type structure toward the front. Much easier and faster to print, too. I don't remember where the file is at the moment, I can look for it when I get back.
