Building Elvee's Circlophone: Documentation, Parts, Accessories, & beginner friendly
I successfully used TTC004B as VAS transistors on my circlophone. I currently have only one channel working on a temporary heatsink. Testing so far has been rather minimal. Both channels will go into a permanent enclosure next month. PCB is my design: the only significant differences from most other circlophone PCBs are changing the VAS transistors to TO-126, and moving the KSA1220 drivers and MJL21194 outputs to better support mounting the PCB on the heatsink.
Thank you dear Frank ! Received the PCBs (by my nephew. Will reach me shortly) and the files. Thank you very much !
Did you complete the assembly and is the amp working normally ?
gannaji,
I completed this amplifier build about eight months ago and am very happy with the result. Speakers used with this amplifier vary but is currently is an Aplair 10m MLTL. Power supply is a Connex SMPS300RE +/- 35V with an ebay "2409-2" aluminum chassis.
Attached is a picture of the two boards mounted on their heatsinks. This arrangement allows for a more compact build and probably better heat dispersion than with boards designed to be mounted horizontally.
I answered this question by PM, but for the benefit of the whole community, I shall restate it here:
The diodes are ideally any schottky in the (loose) 3A to 10A range, but fast Si diodes will also work, with a slight loss of output swing.
Even ordinary slow diodes are going to work, but if you test the amplifier with a full power >10kHz signal, the quiescent current will wander outside its normal bounds, but not in a catastrophic or even audible manner, because the power will be sufficient to mask any potential Xover artifact.
Anyway, schottky's are ubiquitous nowadays, so they shouldn't be a problem.
With C4's value, all the possible alternatives are suitable: MLCC COG, or any other tempco, idem for ordinary ceramic, mica, polystyrene, air, polypropylene or even vacuum: even if you tried to, you couldn't go wrong there, unless you try to make your own cap from orange peels, cotton cloth or similar improvised material.
Any other question useful to the community should be posted directly on the thread (main or build).
PM's should be used for private purposes only (personal information, payment details, etc)
Can folks provide guidance .Is this for +/-25V @4Ohms .
A colleague of mine has built one channel for me and reported 200mA on primary 20-0-20 transformer side !!
However the amp is working . He was delighted with what he heard.
Thank you Elvee !!!
Refer to the first post of this thread: Building Elvee's Circlophone: Documentation, Parts, Accessories, & beginner friendly
You can find the ideal values according to the supply voltage.
Note that this is not at all critical: a C built for +/-25V will accept between +/-15 and +/-40V
It is clearly abnormal, and I see two possible explanations:
-The circlophone actually consumes almost 50W, instead of 5W. This could be due to a dry joint, short, or misplaced component in the servo circuitry, making the amplifier to operate in ~class A.
In that case, heatsinks dimensioned for normal AB operation are going to become boiling hot after a few minutes of operation.
-The transformer has an excessive magnetizing current, because of poor quality iron, bad construction or inadequate primary voltage.
This is not a source of problem, unless the transformer itself becomes hot.
To determine whether the current is reactive or not, your friend should measure the active power consumption using a wattmeter rather than an ammeter.
Here is an example (there are many of them): Kill A Watt Meter - Electricity Usage Monitor | P3
If the (active) power consumption is <10W, everything is fine, it's just the transformer.
If it is larger, your friend should examine the C he built.
Without a wattmeter, he can also disconnect the DC supply from the C and check the current consumption: if it remains high, the transformer is the culprit
If it works in class A, he is certainly going to be delighted (until a meltdown occurs)
