Is it possible to cover the whole spectrum, high SPL, low distortion with a 2-way?
make that make sense.
It makes all the sense in the world.
Double-clicking on the Pmax slider label selects the Maximum SPL mode (see the Help file for details).
Leave the Pmax and Xmax sliders disabled and simply adjust the Eg slider if you want to change the input level (2.83V = 1W into 8 ohms, 4.00V = 2W into 8 ohms, etc).
Im just a noob at hornresp, that’s all
Besides, I may doing too much. Sealed mid/bass and slot ported sub...I’m not loosing if I just keep it simple.
What do you guys use for fill?
I’ve been looking up enclosure design, seems like 1” mdf would be fine with minimal bracing and some acoustic dampening material on the walls and call it a day?
According to Magico:
attachment.php
Source: Q Sub — Magico Loudspeakers
They build a sub that can do a bit more than what you're asking:
Built around the renowned Q platform, the Q-Subs set new standards in low frequency sound reproduction. Capable of delivering 136 dB sound pressure level with less than 1% total harmonic distortion at 20Hz, the message is simple: if you think you have heard low frequencies before, think again.
But the pictures make me think some bracing would not have to be a bad idea. Now yours will be ported though, not sealed like their monster subs...
To some of us you are, but stuffing the cab/vent brings you close enough for most folks.
I'm old fashioned as I prefer fiberglass insulation since it has the 'right' properties for it [or at least did].
Don't have my calculator available, but from memory it takes 1.125" thick MDF to match close enough to 3/4" [19 mm] no void marine grade, BB and apple plywood's ~1.8 mil psi stiffness [MOE], which with any decent size sub will still require significant bracing to make it 'ring' like metal where it ideally needs to be and while bracing increases stiffness quicker than thickness it will still require a lot more, so ideally start with 10 ga CRS with cast iron angle bracing and 'U' channel iron fork lift skid plates to move it around and with this much stiffness, mass it won't need anything but a motor brace. 😉
While a cab designed to deal with the hum of an electro-mechanical 10 kV motor controller is a bit overkill for your app, it's not as excessive as you might think when trying to eek the most acoustic efficiency practical out of a speaker cab, so think 'stiff' first and foremost with mass a close second to keep it 'planted', which if a separate cab can have removable mass on top.
GM
I looked it up and was kinda shocked that 1” 6061 aluminum plate weighs 70.56 lbs per sq’ !
I don’t know what it’s made from but probably something like that to weigh that much.
I would have guessed 20-30lbs at most per sq’ for 1” Al ....crazy!
Ron, the Magico specs don't add up.
Even using the 6000W 230v double 18", a 90dB sensitivity would equal about 127-128dB assuming zero compression, which is nuts.
To say there's only 1% distortion at 136dB is surely fantasy, for any double 18"s on earth imho.
I'd say they are most likely tying to spec and price their subs by the pound/kilo 😀
I was reading about dual panel walls with sand in between the layers. That’s a thing I guess.
It's about increasing stiffness, mass loading, to provide a stable, inert working platform for the driver while not being excited by it, but when I 'ran the numbers' decades ago it wasn't heavy enough to either push the cab's resonance below it's tuning or stiff enough to raise it well above it, so while certainly an above average performer, wasn't all it could be and why I prefer pushing the cab's resonance ~ an octave above the drivers pass band with high MOE materials, proper bracing.
GM
