freeDSP-aurora - DSP with 8 I/Os, USB Audio, S/P-DIF, ADAT, Bluetooth and Wifi contro
Hello all! I tool a quick look on freeDSP software, and i don't see "classic" channel mixing console. It is not intended to such use, or i am not seeing something obvious? :) Thank You!
That is because you only see the 8channels plugin when you run auverdionControl in standalone mode. DSP plugins can define channel mixing. E.g. the HomeCinema71 does a downmix for the subwoofer.
I am using Naja DSP and I am waiting for the promised MAC support since 4 years......i am very impressed by Aurora DSP project, so it could be a solution for my soon active speaker projects alternatively to the new hypex plate amplifiers or mini dsp.
hypex advantage is automatic input source detection (analog & digital), will it be possible with aurora ?
regards
murphy
There was some talk on the Audiophilestyle forum that the owner of Najda DSP / WAF Audio who was on a motorcycle trip and had an accident - I’m not sure if you’ll see anything more from them and the website is no longer live. I hope the guy is ok, but it seems as though auverdion is the answer for now.
