Can you hear a difference between 2 solid state preamps?
Can you hear a difference between the two test files
  • I can hear a difference, but have no ABX result
    Votes: 12 50.0%
  • I cannot hear a difference and have no ABX result
    Votes: 6 25.0%
  • I can hear a difference and have an ABX result
    Votes: 4 16.7%
  • I cannot hear a difference and have an ABX result
    Votes: 2 8.3%
  • Total voters
    24
  • Poll closed .
After some time, there is a listening test again. This time, 2 solid state preamps based on opamps and JFET transistors are tested. The test files can be downloaded from
http://pmacura.cz/worldstring.zip
The question is if you can hear the difference between the two files and of course the ABX result would be appreciated, as always, but is not mandatory.
Your comments telling which of the files you prefer by listening will be appreciated as well.
Nov 8, 2019: for those who might be interested, there are new samples
http://pmacura.cz/claire.zip
Now, it is a contemporary recording issued by a highly regarded record label. To make it not so easy, there are 3 sample recordings now. The same preamps were used in the test as for Sinatra files. Please comment and bring your sound impressions of the new samples.
Did you do any basic measurements on the pre-amps?
From the measurements, would you call either pre-amp 'Accurate' or 'Euphonic'
As you would probably guess, I have a full set of measurements of both units. However, I am not going to show any plot before the poll is over.
As to your specific question, both preamps may be described as accurate, very linear, with wide frequency range and low distortion.
Several technical notes on the test files - the files are recorded in 24-bit resolution and they are in 96kHz/24bit format, however the music signal limit is 20kHz, due to test music sample used. DAC/ADC path is the same in both cases with same settings and levels. The 2 preamps under test have volume level matched within 0.04dB only by use of the preamp's volume control pots. No digital volume matching was used, no frequency equalization was used. Switching spectra (at the same time point) of the recorded files shows they are almost identical. The main difference is in quiescent noise level, which can be seen in the attached spectral plots, but only at frequencies above 20kHz, as this difference is completely masked, in the plots, by the music signals, in the audio band. The plot images are named apple and pear, to exclude relation to the test samples.
With my best concentration on sound:
Code:
foo_abx 2.0.2 report
foobar2000 v1.4.8
2019-11-05 12:29:21
File A: worldstring1.flac
SHA1: dd4095af5322127d4db4220fcb35696161b23e70
File B: worldstring2.flac
SHA1: 74034a929c8176706e3fc5e9d44a315084e9c54f
Output:
ASIO : Creative Sound Blaster ASIO
Crossfading: NO
12:29:21 : Test started.
12:30:55 : 01/01
12:31:10 : 02/02
12:31:36 : 03/03
12:31:55 : 04/04
12:32:03 : 05/05
12:32:28 : 05/06
12:32:42 : 05/07
12:33:02 : 05/08
12:33:02 : Test finished.
Total: 5/8
Probability that you were guessing: 36.3%
 -- signature --
71ae3bf697b0f34e08c1e5ca304feb80d2d6d3d0
a following one:
Code:
foobar2000 v1.4.8
2019-11-05 12:45:53
Output:
Crossfading: NO
12:45:53 : Test started.
12:47:07 : 01/01
12:47:22 : 02/02
12:47:37 : 03/03
12:47:52 : 04/04
12:48:08 : 04/05
12:48:23 : 04/06
12:48:38 : 05/07
12:48:54 : 06/08
12:48:54 : Test finished.
Total: 6/8
Probability that you were guessing: 14.5%
 -- signature --
4147cb7f8d3e7a9342bac70ac14fecc29715b376
Yes Dan, please. As I said, this time subjective descriptions are welcome. I only will not disclose anything about preamps before the poll is closed.
Ok, I find with quick not paying 100% attention with 4 x listen to the pair (looped playlist) that WS1 is 'harder' sounding and gets 'messy' on the brass solos and vocal is not right, sort of a buzz tracks with the program, WS2 is overall 'friendlier' and clearer and does not get so 'upset' by program, I could live with WS2 maybe, certainly not WS1.
I can take more careful listen tonight and take written notes, I can A/B all I like then without driving my housemate nuts lol.
Dan.
Thank you Dan for your comments.
I think I could reveal the biggest (probably) difference between the preamps under test, and this is the frequency response. Though they are both well within 0.1dB in 20Hz-20kHz range, there is quite a remarkable difference when we extend the range to 1MHz. This also reflects, of course, in 10kHz square response and corresponding rise/fall time of the leading/falling edges. Frequency responses shown without revealing which one belongs to which preamp.
