Can you hear a difference between 2 solid state preamps?
Can you hear a difference between the two test files
  • I can hear a difference, but have no ABX result
    Votes: 12 50.0%
  • I cannot hear a difference and have no ABX result
    Votes: 6 25.0%
  • I can hear a difference and have an ABX result
    Votes: 4 16.7%
  • I cannot hear a difference and have an ABX result
    Votes: 2 8.3%
  • Total voters
    24
  • Poll closed .
Pavel can perceive the difference on the 3 very low distortion preamps, however I do not find any of them to be poorly designed.
What does that have to do with results of DBT I mentioned?
It actually is good for you if you can not hear a difference, no incentive to spend on more expensive parts like the AD797. Better yet when you find a cheaper parts like the TL072 to sound the same. Too bad for those who do hear. 😀
Must you attack people so often on forum? 🙄
<snip>
......, the subjective version is just that, no level matching, no visual bias controlled, no memory span compensation and no room mode accounted for. The level matched version was done by volt meter at the speaker terminal when amps were switched.
As for Markw4's secret listening test method, will you be asking the same?
I was just asking for the detailed description of your listening tests; if you've never done any serious, rigorous controlled listening test, just say so. 😉
