Long skinny builders thread
From nightly sketch up. What do you guys think?
Common guys NP's generosity to share ideas is enough for me.
This really is not enough to keep you busy?
We should just explore from a hundreds or thousand ways permutation how to get rid of heat.
Leave that signature heat sink design to FW customers, or just buy the original?
Its about design with similar heat transfer and esthetics for greedy boyz, but recognizably different not to be usable by unauthorized cloners. Those do not look different enough to original FW fin pattern?
@indra1,
There's something to like about the simplicity of that last one.
The Modushop drawings don't include the mounting holes for the back, so I'm not sure what the spacing is. It also occurred to me that the Modushop front panels are attached from the back rather than drilled-through and counter-sunk, so maybe there's no advantage to be gained there anyway....
Jeff which mounting holes are you refering to? Let me know if I can be of any help.
And yes, all our 10mm front panels are attached from the back
