USSA-5 Build with Review
I made some progress 🙂
The SLB psu is good to go and the USSA5 boards are ready for the first stage of adjustments.
Hi Meanie
have you tried a classic PSU A / B against SLB ...
you heard some difference?
Τhanks
My USSA5 is about to get house into a new chassis, currently having the heatsinks drill n tap.
So far very happy running with the CRCRC ps. When It does goes into the chassis, it will be powered by SLB.
Then I will post some findings then.
I m still waiting for the proper transformer for the SLB
I have a few heatsink options for the USSA5.
This is the smallest size,
300mm x 125mm x 25mm (fins) with 10mm base thickness.
My planned psu will be 24-26vdc with approximately 1.3A bias current.
What do you think Fellas, will this HS option be adequate for the USSA5?
