Hi Fab,
I’m unclear if RV1B/RV2B are removed once RV1A/RV2A are calculated and installed? Thanks.
Thanks Zman!
I’m waiting for a new metric tap set, I snapped the M3 tap during my last use 🙁
So probably not getting first sound this weekend.
Quite frustrating Vunce when you break a tap... and even worse when it delays your project. Don't ask me how I know. 🙂
Hi Fab,
RV1B/RV2B stays in place too, after calculated and installed.
Hi Meanie
have you tried a classic PSU A / B against SLB ...
you heard some difference?
Τhanks
My USSA5 is about to get house into a new chassis, currently having the heatsinks drill n tap.
So far very happy running with the CRCRC ps. When It does goes into the chassis, it will be powered by SLB.
Then I will post some findings then.
I m still waiting for the proper transformer for the SLB
Last Sunday I viseted Asanden and we did listen to some music .
USSA 5 and B1Nutube , perfect combo for me .
Good progress Vunce 🙂I made some progress 🙂
The SLB psu is good to go and the USSA5 boards are ready for the first stage of adjustments.
I really like the parts you use for test point
Can you share part number.
Fab
...I really like the parts you use for test point
Here you go Fab:
5002 Keystone Electronics | Mouser
They are very handy to have, the Fluke “pincher” style leads attach very securely to them. You can find them a bit cheaper than Mouser, try eBay 🙂
I have a few heatsink options for the USSA5.
This is the smallest size,
300mm x 125mm x 25mm (fins) with 10mm base thickness.
My planned psu will be 24-26vdc with approximately 1.3A bias current.
What do you think Fellas, will this HS option be adequate for the USSA5?
This could be ok but it depends on your tolerance on the heatsink temperature ��
To not exceed 50C you may have to reduce the bias between 1.1 or 1.2A.
Fab
Fab
Thanks for the feedback, it is quite useful to know which match works fine.🙂Last Sunday I viseted Asanden and we did listen to some music .
The B1 Korg Nutube has very good review from what I notice.
Fab
Small progress spare parts...
I think that is 534-5000.Love those test point pins from Keystone, thanks Vunce for sharing.
- USSA-5 Build with Review
