Usual thing. Projects andThere seem to be more buyers than builders 😀
PCBs have to ripe.
I have assembled a pair of THT modules using IPP029N06 MOSFETs. These will be installed in my M2x amplifier and tested over the next couple days.
There have been several posts about which MOSFETs to use. Choice depends on the secondary voltage of your power transformer, and how much current your amp will draw.
Request 6 x THT
Hello Prasi,
I will send you PM with Paypal address for 6 THT if they are still available.
Thanks!
Ron
Hello Prasi,
Thanks!
Ron
@Tungstenaudio and nounouchat
Thanks folks. Just want to see what MOSFETs did people choose and how they like it😛. I don't have a project that needs the rectifier yet. So I am taking my time to build.
Assembled the ideal bridge modules but not tested yet🙄
Fab
The assembled modules look great!!
Fab
Hello Fab,
The build looks great. All the best for testing and success.
regards
Prasi
Thanks for kind words!
As you can see I have found a way to fit them into a standard psu pcb within the area planned for the normal diodes but active rectifier board installed vertically😉
Thanks Prasi for doing this pcb layout and handling this group buy like a champ!
Fab
Fab
I have my boards.
Thanks prasi!
you are welcome! all the best for your build. BTW, very nice speakers in the background!.
regards
Prasi
I have had the 4320 rectifiers in my M2x (clone of First Watt M2) for a few days. They replaced a set of FEP30 diodes. Given an Antek AS-4218 as the power transformer and 1.31 Amps class A bias current, the rail voltage on the channel boards increased from +/- 22.4V to +/- 23.6V. Ripple on the supplies decreased enough to be less noticeable with the experimental input stages that I’ve been working with for a while. (They have a lower PSRR than usual.) Measured ripple was 24mV. Switching to a pair of my favorite tweaked Mountain View input stages let the new power supply really show its quality. My M2x now is on equal footing with the Aleph J and its dual-mono power supplies.
Hi Prasi,
I'm finally going to make my rectifiers.
I have 4 LT4320 in MSOP format, do you have MSOP adapters?
nounouchet
nounouchet
Hello Nounouchet,
I do not have the MSOP adapters.
However I have posted the design here.
LT4320 based active rectifier
You may order the PCBs from any of the board houses.
regards
Prasi
regards
Prasi
I plan this month to order PCBs for my DIY project and i will order cpl of Prasi design MSOP adapters. if interested for cpl MP..( you pay just for shipping )Ok thanks
- Group Buys
- LT4320 based active rectifier
