Babelfish M25, SissySIT - general building tips and tricks
you didn't read this thread from start ?
contact : https://www.diyaudio.com/forums/members/pras1170.html
both THF51S and 2SK182ES are proven parts , if you ask for 2 pcs with Ugs adequate for SissySIT
also watanabetomoaki on fleabay , choice is yours
what's important is that Ugs is no greater than [-3V8] with 24Vdc rail and 2A for Iq
Oh, like 10 times all the way from beginning 😀 It just seems that young mind can’t remember everything.
nicer :clown:
several reasons , depending of circumstances - with automated insertion , robots like more resistor form factor than wire form factor
when ZM insertion is in case :rofl: , I like more that I don't need to think about additional insulation ....... besides, less work than stripping isolated wire etc.
also , when 0R or something else is going to be in 1-pin holders (sockets) it's sorta nicer and easier to manipulate with resistor form factor
nicer :clown:
Great so since it’s me doing the insertion.. will go for the jumper 😉
Another question : is 1/2w resistor ok for all the 100r in the sissysit? I’m sure it’s ok for r1 but nut sure for the other. Not enough knowledge to compute 🙄
100R resistors - size (them all!!!), mistakes and mishaps
all resistors in Sissy and Babelfish M25 are regular 0207 size , meaning - your plain old good Metal Film resistor ...... nowadays being more like 600mW , not 250mW as in Yore
yup , I got several bags of 100R ones from my Vendor , sized more like 1W (somewhat bigger than 0207) , but I didn' made a fuss about that , simply because they are not too big - right enough to be put through holes without awkward bending of da legz
however , and this is important:
as I'm informed ( twice !) in last few days , it seems I had some strangers in my 100R bags , so please check all 100R buggers you got from me
blame is on me
(as always , and I'll blame Papa , as always) , that I didn't catch that and packed them and labeled together ...... but primary blame is on my Vendor - I know that they all were in same plastic bag , prior to opening it and pouring in plastic drawer ......
I got one sneaky one...
Not a worry ZM. Thanks for letting us know. Great reminder to measure EVERY resistor before stuffing...
Is it brown, black, black, brown, brown... or brown, brown, black, black brown? Hmmmmm?
I already wrote before - Conrad.de is having nice assortment of Keratherm thingies
it is on other side of Pond to you US guys , but you can't have all
:rofl:
though , SITs in case are sooooo big ( comparing to dissipation) , no need for Keratherm ...... even blanket is good enough :devilr:
Finally got the chassis. Test fit of SITs. I have determined that I have zero skills for tapping. Went through 2 bits and a tap for 4 holes. Learning as I go...
If all things go well, I should have a dual mono PSU and new chassis set up for it tomorrow or Thurs 😀.
Use WD40 for drilling and tapping. Take it slow and gentle on tapping, back it out and remove the dreck often. Summary: slow, gentle, lube.
I learned the hard way on re-purposing some Rawson amp chassis by breaking a few taps.
By the way, tap jokes never get old (to me).
I cut out the R13’s after I saw the big note
Phillips caps installed.
Waiting for Cinemags...
I saw the note about 100R - it looks like a few stray critters made it into my shipment! One on each board. My habit is to measure first one I pull from a bunch. Oops. Easy fix, glad I caught it now. Early is much better.
