Rev does not use USB power , it has dedicated power inlet.
As far as ground , we used filters for ALL inputs (USB included) so your Gnd is filtered.
Today we have tested for IMD. I am happy to say that "ess hump" is non existent in our DAC
Note also that IMD is equal to the best measured DAC Okto (rather more expensive)
Nice, I wonder if galvanic isolation, or a USB to spdif/i2s lvds converter will still make the sound better on the revolution DAC as it does on many other DAC. I kinda don't like DACs where the sound becomes better when used with a converter as that just means the input was sub optimally done even DACs costing over 1300$+ are not excempt from this.
Thats a question that cannot be answered since it depends on many variables
USB to spidif/i2s...what type of jitter it will introduce ?
Note that we are already using a USB to i2s (xmos ic on board) and that IC is feed multiple indepedant LDOs. I can post the MCLK . CLK LRCK and you can see they are close to perfect waveform
Galvanic isolation ...you already have it using a product like USbridge sig or RPI with ethernet being galvanically isolated (and in case of UsbS further cleaned with CMC filter)
At last , I think it might be dependent on your setup with the specific ground loops.
But I suppose it can be used as a pure USB-DAC with a special split USB cable (as you said in a former post), so the power requirements are not higher than 500mA?
Matt
Yes it can but it depends on your USB output, there is a lot of capacitance on board and your USB device might not support it.
We do advise to feed independent power.
Ahh yeah your right there won't be multiple earth paths if both DAC/usb Sig is powered by same LPS, I forgot that, just need to make sure to use unshielded UTP Ethernet cable with some distance from power lines as shielded can still carry ground loop from router/modem/coax cable which is usually connected elsewhere in the house for most people.Thats a question that cannot be answered since it depends on many variables
So can we expect the DAC to ship in October if everything goes well?
As far as I understood the network chip on usbridge sig will needs an additional driver. I use picoreplayer. Any chance that driver will be available with this distro?
Best
Best
We are already talking to most distro and will be available at lunch depending on theire integration
If not integrated , please note that it will still work at 100Mbs DSD 256 I think
Apologies if this has been answered before, but does the USBridge Signature have on-board wifi, and if so is it the same as the standard Pi?
Alan
Alan
No wifi on board , but we have added 2x USB ports in front of the box labeled wifi/bt
In fact we are testing a new wifi dongle right now with excelent results (and we will have it for sale)
PCB house in China was busy but finally they advised the new PCB for Revolution (last revision) will be shipped by next Friday.
Those are golden ears samples
Exciting news!
Great news! Sonically speaking, would you recommend using the WiFi dongle or Ethernet sans "audiophile treatment"?
Use Ethernet.
We cleaned up further on the above interface using special CMCs (after the isolation transformer) that work at 1000Mbs and are designed for noisy automobile environments
What is J10 on the USBridgeSig for? Network? It looks like a dual USB port from the top, but I can't be sure.Latest USBridge/Audiophile SBC PCB
Corrected some R , better mechanical integration .
Final testing on this board should be completed in the next 48h.
I only see j12 and its shorted on production pcb its earthing connection of the DC input to case
- Vendor's Bazaar
- Shanti Dual LPS 5V/3A , 5V/1.5A
