Macfizer,
For the A10p i’d try to get the volume down to about 17-18 litres. Some bracing could help too. The extra 30 litres is sufficient to accomodate a woofer to make a WAW.
dave
dave
Full Range driver
Hi folks, being that everyone here has tried full range driver, can anyone tell me their thoughts on Audio Nirvana's Super 8 alcino plus? I am looking to buy these. They run about $1,600 bucks so Id like to make sure Im making a good purchase.
Thanks in advance.
Thanks in advance.
I haven’t heard them but i believe that, from the changes in the parameters from their other 8s, this driver is more marketing (to be able to say it is Alnico), as the magnet strength looks to be way down.
It will thou, at least in the sims, will produce bass unlike some of th eother 8", but getting the box Q down means a BIG box, aperiodic loading or OB.
dave
dave
do you reckon if this would work with the ps95-8
How do you like the needles? I just ordered a set of the Dayton's for PC use. I'm going to build a small BR enclosure for them and really looking forward to them arriving later this week. Beautiful enclosures BTW!!
Scott
I'll start... This is my 3rd pair of "T-Horns"; too bad I couldn't keep them, because I sold it...
WOW. Gorgeous. No wonder you sell them.
Hi Tony,
I like the side details on this pic better than the other details (detail of horn internals).
Externals don't reproduce music. I would LOVE to see the internals. Please. Please.
Not quite fullrange, but I thought I would post these anyways. Fostex 108e sigma, and an Eminence Delta 12lf. First order on the fostex, second order on the Eminence, centered around 300Hz. I'm quite thrilled with them, and have been so for some time. Still a little bit of tweaking that I would like to do, but I guess that never really ends....
Joe
The parlor of Ravi Shankar 🙂
Wood VS MDF
This thread is 14 years old, but I have some 2019 MDF-based Andrew Jones ELACS, and I can hear the box. The drivers are fine, but the enclosure is crap. MDF might be closer to inert, but Stradavari were made from wood. I'm going to look for some Baltic Birch, but I bet most any cold-weather wood will sound better than MDF. Think about it - the enclosure vibrates at the same rate as much of the music, and it will color the cone to some extent. If MDF is absorptive (and I am way out on a limb here) It could potentially damp the drivers and rob tone. Plus, its just a gummy, cheap material that just is not of "instrument" quality.
Fire away.
Sounds like you got a real deal on that plywood. I sure wood like to know (sp. pun intended) what is the reason behind your discovery that the MDF cabinet sounds lifeless and the Baltic Birch ply version is musical. I know that the use of certain woods, chosen for their resonance qualities is essential in the manufacture of some musical instruments where the vibration of the case itself contributes to the harmonic tone structure of the instrument, but that is the opposite of what we want in a good loudspeaker cabinet. In this instance, as we know, we strive to avoid cabinet vibrations and resulting 'colorations'. Still in the end the proof is in the pudding and if the plywood cabinets make magic for you and the MDF ones miss the mark then you should IMO consider yourself very fortunate having been sucessful in your goal after making only two practice cabinets. Magic tone in audio is elusive, but well worth the quest.
Fire away.
Well, I think in short in a Strad, or a solid body Fender Strat, the material from which it's fabricated is there to help make the sound, while an ideal speaker enclosure would be made from material that is at least inert -if not a "sink" for all spurious vibrations not immediately associated with the music.
But since the huge majority of real world speakers - and most particularly affordable mainstream commercial products- are constrained to real world materials, I'd supect designers such as Andrew would probably admit that the bean-counters will only let them get away with spending so much money on the boxes in a pair of speakers retailing for, let's say under $800?
Expect to hear now a variety of options on combinations of materials and construction / bracing techniques to mitigate enclosure resonances and approach the ideal alluded to above - not the least of which will be Open Baffles are the cure for all the evils of monkey coffins.
there is no silver bullet
Just finished two ml-tqwt's for Alpair 10.3
Design (or dimensions) is pretty close to frugel xl, but I wanted straight enclosures and no curved back. Port tuning is adjustable. Sounds pretty good actually and the amount of bass is absolutely ridiculous! Lower cutoff is somewhere around 40Hz, line tuning about 45-50Hz.
There is bump at 200Hz and severe dip at 230Hz, need to figure out that. Propably some harmonics going on and messing things which is typical for tqwt enclosures.
Also lots of presence from those alpairs but in a good way, not annoying at all. Highs are little bit "harsh" sometimes. Overall, satisfied results.
Finally finish full range TB W5-2143, and I am very impressed by the result and of course the amazing sound coming up from such a small driver and small enclosure.
Everything done by myself from the cutting, assembling and painting, very difficult here in Philippines find a good wood so no choice I used a 16mm marine plywood for the main body and from the last project a 24mm baltic birch plywood for the top and bottom. Stained with Nescafe instant coffee 3 coat and finish with 4 coat of Konig polyurethane and a little touch of design on the front for cover some imperfection of the plywood. The enclosure follow the Tabaq design, sound stage and clarity of middle and hight freq is outstanding for do not talking about the punching warm bass response…..all the best
Nice TABAQs!
I like the instant coffee look. And the little Tetris design.
Watch out that no one tips them down! You might want to add a wider base so they are more stable.
Enjoy!
Enjoy!
just got my new SWR096-8A Sonidos 🙂
tnx to Mr. Varga , excellent product , as always
as I'm used to say - these reminds me on GrandMa's Telefunken , just made with modern materials , where's important and beneficial
once more
last two pics taken from sonido.hu site , few examples of boxes made by customers
still didn't decided where my are going to end , box wise
most probably will keep them some time near my PC desk , to enjoy just looking at them
edit - and yes , they're ovals , no broken pics , even if I took them with phone 🙂
They sound like this ....I wanna get me a pair of those Sonidos. I’m eager to find out how they sound.
Many years ago I built a small horn speaker from the Sonido FR 5". Last Summer I finished FR BR (Full Range Bass Reflex) speakers with the new SWR069 drivers from Sonido and the sound really knocked me off my ... the chair.
I have never ever missed anything when listening to my small horn speakers, but suddenly I got the same "audio signature" but a lot of it, nice and clean mid and highs but a much lower low.
At the moment I am using a small compact 3W Chian-amplifier (6P1) and that is definitely enough for my 20sqm livingroom.
soundbrigade , will send you MLTL box sketch as soon I'm done with it
according to my experience - that type of box is usually better than BR for similar speaks ...... and due to lower cone amplitude for same SPL (vs. BR) , mids are also cleaner ...... Doppler etc.
buzz me in a month or so if you wish .....
- Full Range
- Full Range Speaker Photo Gallery
