Ready-to-Run (RTR) SSR DC Speaker Protection and Delay GB
Neurochrome.com
Joined 2009
Tom Christiansen suggested that the circuit be tested under load connected to a low distortion amplifier. I acquired one of his Modulus 86 amplifiers that is capable of 40W out into an 8 ohm load. My test setup uses an Akitita low distortion 1 KHz oscillator as a signal source and a first generation Focusrite 6i6 connected to the amplifier via a 10:1 attenuator. Using REW to measure the apparent distortion. I first tested it without the SSR protection circuit and adjusted the input to drive the output to just above 18VRMS into 8 ohms.
The first plot shows the results. There are no apparent distortion products above the noise of the test setup.
Fantastic! Thank you for following up. It looks like the lowest THD you'll be able to measure with that setup is around -110 dBc 0.0003%, which is considerably lower than the THD of most DIY amps. That's excellent!
There is no discernible difference in the output harmonic content with or without the speaker protection circuit in place.
"...that I can measure with this setup." I agree with your assessment otherwise, though. The THD contribution of the SSR is below -110 dBc. That's excellent.
Should you wish to further improve your measurement capabilities, I suggest looking into twin-T notch filters. If you notch out the fundamental, your measurement becomes less limited by the dynamic range of the sound card. Of course, should you choose to do that, you'll likely just find the harmonics of the oscillator itself. Should you wish to further improve the oscillator, contact Victor (vicnic). I have one of his oscillators underway by mail. It's supposed to get me below -150 dBc THD. That'd be nice.
I'm not suggesting that you go through all this trouble to characterize the SSR - at least not for my sake. Measuring low THD takes some real work. I'm just throwing it out there in case you'd like to satisfy your technical curiosity.
A twin-T is easy to build. Just make sure to use metal film resistors and polypropylene caps so you don't get appreciable distortion from the filter itself. You'll need to match the resistors and caps to get a good notch. Don't forget to characterize the filter response, as it'll attenuate the harmonics some. You'll need to compensate for this when you calculate the THD.
Very nice work Jan. Can you click the THD analysis button so that we get the inset window showing % HD from various components up to H9?
Most should be able to look at the data points at 2k, 3k, 4k ... and see that there are no harmonics sticking up above the noise floor of the measurement. What you'd get from clicking the THD button is the THD+N. I suggest pondering the internal validity of such experiment. ;)
Ahh... Life in the precision lab. Your instruments may lie to you.
Tom
Founder of XSA-Labs
Joined 2012
I think with some settings changes, the thick grass at the baseline could be reduced and perhaps a glimmer of some sort of peaks at 2k, 3k would show. The peak from the Akitika might be observable. I am not sure why the grass on mine is not as tall?
773219d1565161249-ready-run-rtr-ssr-dc-speaker-protection-delay-gb-05-vhex-14-12vrms-8ohms-yes-protect-jpg
xrk971 - 4 units - USA
pinnocchio - 2 units *Pre-order Placed*
Vunce - 2 units - USA *Pre-order Placed*
Miggie78 - 2 units - FINLAND
gary s - 4 units - AUSTRALIA *Pre-order Placed*
WTL- 2 units - AUSTRALIA *Pre-order Placed*
ppap64 - 2 units *Pre-order Placed*
drpro - 2 units - USA *Pre-order Placed*
Alarudin - 2 units - SINGAPORE
Ripcord - 2 units - USA
Myint67. - 4 units - Singapore (depends on price )
ravid - 2 units - India *Pre-order Placed*
darrr - 2 units - Poland *Pre-order Placed*
necplusultra - 2 units - Dominion of Canada
gannaji - 4 units - USA
Amplitude - 2 units - Denmark
esprit - 2 units - UK
hirscwi - 4 units - USA
yoaudio - 4 units - USA
kamco - 2 units - USA *Pre-order Placed*
Baobei - 2 units - UK *Pre-order Placed*
Kokanee - 4 units - Canada *Pre-order Placed*
Abanico - 2 units - Spain
vasilis - 4 units - Greece
astromo - 6 units - Australia *Pre-order Placed*
mlloyd1 - 2 units - USA
markus22ch - 6 units - Switzerland
redjr - 2 units - USA *Pre-order Placed*
gtose - 2 units - USA *Pre-order Placed*
jwjarch - 4 units - USA *Pre-order Placed*
gktaudio - 6 units - USA *Pre-order Placed*
quadtech - 2 units - USA
livingstone - 4 units - RUS *Pre-order Placed*
Bare - 2 units - Can
MD_Stryker - 2 units - USA
tuyen - 2 units - Australia *Pre-order Placed*
evanc -2 units -USA *Pre-order Placed*
tcpip - 6 units - USA *Pre-order Placed*
Pilcom - 2 units - AUS *Pre-order Placed*
Hey X, I need to cancel my order of the RTR SSR. I did order the SLB psu which is what I needed more. Sorry bout that but am excited to get the SLB!
Founder of XSA-Labs
Joined 2012
No problem, Ripcord. Thanks for ordering the SLB - destined to be a staple of Class A amps.
For other folks on the fence about the RTR SSR Protection board: $80 is a very fair (even a bargain) price for a built and tested state of the art solid state relay protection and startup delay circuit. How much does the woofer or tweeter on your speaker cost to replace? Do you worry what would happen if full-rail DC was released on your speaker when you are not watching? Do you have an issue with amp startup thump? These worries will all be solved with a super easy to install RTR SSR protection board.
60 units still available. We are still waiting for delivery of the first build checkout unit from the assembly house.
Neurochrome.com
Joined 2009
Is there a link for one of these super oscillators?
"Yes": Low-distortion Audio-range Oscillator :)
Actually. If you go to above thread and search for "victor schematic" you'll find the schematic. There's sadly not a website that I'm aware of. Contact Victor directly via PM (vicnic).
His earlier versions reached below -140 dBc. The new ones are even better. They're ~$60, so money shouldn't be the greatest limiting factor. For a while, Victor sold his oscillators on eBay. I couldn't find his listing last I looked, so either he's stopped or the listing has drowned in all the mediocre crap advertising itself as "high-end" or "precision".
Tom
X, I contacted Vicnic through the PM on this site. He apparently takes in orders then will list them on Ebay for sale.
I first contacted him in April of last year and it was several weeks before he sent me the Ebay link to place my order.
So I would say reach out to him, and get on the list or maybe you will be lucky and he has some ready.
Tnx
David
Hi DrPro, I have contacted vicnic and he will have boards ready next week and will send PayPal invoice this time. Looks like a very nice oscillator. Teeny tiny unit too. I will use 4x 9v batteries as it requires 35v dc supply.
What are the oscillators like? Fixed or variable frequency? Can I read about them somewhere? The RX6001 thread is too long...
