Some speaker driver measurements...
Thanks HiFicompass!
Looking at SB34NRXL75-8 Vs ScanSpeak 32W/4878T01, I declare the SB winner!
SB34NRXL75-8 advantages:
- HALF the price
- Better sensitivity/impedance ratio
- Better on and off axis frequency response below 1khz
- Better step/waterfall
- THD+N is close, but SB looks cleaner to me, and also keeps H3/4/5 lower as level increases. Only concern is this 750Hz peak on the SB, which suggests one should cross at max ~400Hz. (on the ScanSpeaker this peak is 6dB less and happens 50Hz higher)
If I can afford, I ll go for this SB for my next build.
..when making an IEC Test baffle:
"Surely a 15" insert is going to be more than enough for all my tests!" 🙂
-until it isn't.. 😱 😛
(..same for 18". ..and then you eye that 21" from Precision Devices, or their 24".) 😉
..and then there is that crazy Fostex woofer. 😀
The measurements of the ScanSpeak 32W/4878T01 woofer:
ScanSpeak 32W/4878T01 | HiFiCompass
The measurements of the new BlieSMa tweeter T25A-6:
BlieSMa T25A-6 | HiFiCompass
Good drivers, as expected of a Scan-Speak Revelator and Bliesma. There might be more compelling options out there for both units, this thread has spent some time on one such option for the Scan. DSA315 would still be a nice comparison in terms of T/S-parameters.
As for the T25A, it brings super-wide off-axis response into the top octave with excellent distortion performance. The 60 degree off-axis extends clear beyond 20k - incredible! But the T25B seems mostly superior, sensitivity is higher with smoother on-axis and still wide top octave. That could be a simple unit issue, but the datasheet shows that as well. It is also much cheaper than T25B, but so is the nice SB26ADC from SBA.
