What is the spec from TD1800 ?
1800 W RMS or Music power @ 4 Ohm ?
? W RMS or Music power @ 8 Ohm ?
does 2 Ohm working ?
ALPHATRONICS TD CLASS WITH 6 PAIRS OUTPUT TRANSISTORS
ALPHATRONICS TD CLASS WITH 6 PAIRS OUTPUT TRANSISTORS NOW COMPLETED
ALPHATRONICS CLASS TD 1800 W 6 PAIR OUTPUT.SOLDERPAD.jpg468.4 KB · Views: 905
ALPHATRONICS CLASS TD 1800 W 6 PAIR OUTPUT.SOLDERMASK.jpg222.1 KB · Views: 764
ALPHATRONICS CLASS TD 1800 W 6 PAIR OUTPUT.P.C.B. THERMAL TRANSFER.jpg359.1 KB · Views: 1,066
ALPHATRONICS CLASS TD 1800 W 6 PAIR OUTPUT.DRILLING.jpg120.7 KB · Views: 1,558
ALPHATRONICS CLASS TD 1800 W 6 PAIR OUTPUT.COMPONENTS.jpg441.8 KB · Views: 1,590
ALPHATRONICS CLASS TD 1800 W 6 PAIR OUTPUT.COMPONENTS ,P.C.B.COLOUR.jpg479.1 KB · Views: 1,701
ALPHATRONICS CLASS TD 1800 W 6 PAIR OUTPUT.COMPONENTS ,P.C.B..jpg400.7 KB · Views: 1,874
look good
waiting for assembled running news
TD1800 on low voltage external 18 0 18
dc voltage collapses to 3 volt dc
warm regards
Andrew😕
What does it mean collapses to 3 Volt ?
is it normally ?
any problem with circuit, not working stable ?
please share test expierience and information
Have to complete these 4 pcbs then will try and rectify fault in TD1800😉😉
Hi Sir,nice amp out there.,can you tell us were we can get those class TD boards..i just want to to make one class TD amp..thanks
Did you finished now ?
dc voltage collapses to 3 volt problem fixed ?
does amp working stable ?
another TD1800 layout for you. Please check for any flaw if you want to try it.
hi , all .
I have 3kw 2*52V and 2*104 V can i use this toroid with Apex H900 ??
No, it's very high.
H900 tef done,,,thnx Sir Miles and Liempoo for the layout
God day to all my co-members can I ask who have a schematic diagram of class TD anyone who have this can I have f he can
Hello sir
My 3k3/2watt resistance posetive side becomes very hot what to do please help me.thanks regard
Hello dear
I have h900 test today .when i power to amplifier my amplifier play but after some time after 1 minute approx.sound gradually slow and diminish.and 3k3 /2watt resistance posetive side heated i changed ic2117 and mosfet but problem remain same.please solve my problem.thank you.
easy to find look
- 900W H-class PA Amp with Limiter
