Is it possible to cover the whole spectrum, high SPL, low distortion with a 2-way?
Joined 2008
Xo by ear. Coax enclosure about 70L. I may open a seperate thread to help improve the config. Here are couple of photos of the speaker build. I got distracted with other things and left them unfinished. Only recently decided to get back to them after few years.
Going to order the Faitals just for fun anyway (the woofers currently too cheap with local supplier to pass up). Will swap the 12” coaxial with ph-4220 90x40’ horn paired with Faital hf108r. I’ll likely ask for help to optimise the setup!
It's not surprising AE got extra orders and since it's a small company, delivery time will increase.
I found a thread again that might interest you. It's french > use translate.
attachment.php
This is inspiring, not sure if such wide driver spacing is acceptable or just a sacrifice in this case. I thought the time was for two speakers to perform as one, c-t-c spacing must not exceeed the width of highest frequency produced. At say a 700hz cover doesn’t seem to make mtm pref for such large drivers
Interior, without 902 compression driver.
Not bad, after 40 years of use.
This guy bought the pair A8s shown on the images, replaced the compression drivers and upgraded the XO.
A simple, entry-level diy-project with respect for the heritage these speakers represent.
