900W H-class PA Amp with Limiter
TD CLASS 1800 MY WORK now corrected
there were some small faults in earlier posted designs, now corrected
  • ALPHATRONICS CLASS TD 1800 W -SOLDER MASK 1.pdf
  • ALPHATRONICS CLASS TD 1800 W - P.C.B.1.pdf
  • ALPHATRONICS CLASS TD 1800 W - P.C.B. MIRROR 1.pdf
  • ALPHATRONICS CLASS TD 1800 W - GREY MIRROR 1.pdf
  • ALPHATRONICS CLASS TD 1800 W - GREY LAYOUT 1.pdf
  • ALPHATRONICS CLASS TD 1800 W - COMPONENTS 1.pdf
  • ALPHATRONICS CLASS TD 1800 W - COLOUR 1.pdf
Pcb has arrived.Test soon.
It does not work properly.The oscillation frequency is too low (about 50 kHz) and I tried to raise it up but not successfully.I've changed different values ​​to coils from 5uh to 200-300uh without success.Has anyone done it to show us the conclusions he came to?
It does work properly. TD1800 is subwoofer amplifier.
