Crossover Upgrade Suggestions
Thinking of replacing some of the cheaper caps etc
Please give your input and thoughts -
Thanks so much!
Picture of crossover attatched
Thanks so much!
OK. The first question (and it's a serious, i.e. genuine one) to ask is 'what is wrong with your existing crossover capacitors?' Or to put it another way, what are the problems or limitations they are causing / imposing upon your loudspeaker, or overall system? With those identified, you can consider what will be the best of the many possible options. It's difficult to make any recommendation worth reading without knowing what these problems are, and what the rest of the system is.
When the speaker is given really difficult recordings it becomes overwhelmed.
They can be slightly muddy at times as well. I would like to have a very neutral/every so slightly warm sound with lots of detail and the ability to organize difficult recordings as well.
Fair enough, and I don't doubt either your summary, or your wishes, but my question stands, i.e. what is wrong with the existing capacitors, or, if you would prefer it phrased differently, how do you know they are the cause of the limitations you mention, rather than something else?
You don't mention what speaker it is, but from the PCB it appears to be a Dynaudio Special 40. That's a reasonable / well designed commercial standmount of its type, but if it's like other Dynaudios, it's likely a 1st order acoustical crossover. These are not without merit when implemented well, such as good phase response &c., but 1st order acoustical crossovers by nature also tend to push the tweeter quite hard, so on fairly demanding material, distortion can be higher than with designs using higher order slopes. It also tends to mean running a higher XO frequency, and that can result in a less even polar response, which in turn can affect tonality. So I hate to say it, and I could be completely wrong (not unusual), but I suspect your issue is simply that this particular design does not meet your requirements, and changing a couple of crossover caps isn't likely to change that.
Better caps and resistors (don't forget them) will give a clearer, more controlled sound.
However, where are you going to put them? A Jantzen Superior (mentioned above) 15μF will take up a quarter of that PCB! That's just one component and your speakers are fairly small.
Good quality drivers deserve the best components. The fact the speaker gets good reviews without shows there is potential there.
Dynaudios have their merits, -punchy, dynamic, outstanding bass- but transparency is not their strongest point. I think what you hear is mainly driver related. Bennic PP-s are not top of the world, but they are decent enough not to impose the mentionad limitations on the sound. Also usually there is a good reason usig bipolar electrolitics in certain positions.One thing is really worth to try replacing the ceramic power resistors with 5-10W MOX types.
Hi kawihornet,
thanks for the uploaded photograph and if you'd be willing to do the same for the copper side of the board, that would be awesome for we would be able to analyze the circuit precisely. Traditionally Dynaudio has been considered to be a transparent sounding product and some would think over transparent. Fashion is a terrible thing and hard to fight against and as things are in audiophile circuits, caps take the blame for practically everything. I have built myself 2 sets of Dynaudio speakers, a 3 way tower (9.5" woofer, 2" mid dome, 1.1" tweeter) and a 2 way bookshelf (6.5" midwoofer and a 1.1" tweeter). All other things being equal, 3 way is undeniably and considerably better performing loudspeaker and I attribute this to the midrange unit.
For the issues you describe, I agree with Scottmoose's assessment, and would recommend a re-design for the crossover.
For $200, you can put together a respectable measurement system and actually find out what's going on, rather than flailing around replacing components that will produce minute differences in the sound.
Chris
Years ago I owned Dynaudio audience 50se and contour 1.3 and both were dull or soft in the midrange. I think a big part of that was the self damping of the plastic cones. I've heard it in so many plastic coned speakers that I'm convinced that's what it is. Obviously it can be caused by a wonky frequency response too.
Assuming it's following the usual Dynaudio pattern it'll be a 1st order acoustic; likely 1st order electrical with a delay on the tweeter & whatever will give the desired slope for the midbass.
OK, final question. When it is said 'I have read a lot of bad reviews on the current caps in use', does that mean you have read a lot of bad reviews? Or does it mean you have visited Tony Gee's Humblehomemadehifi website, read what he said about them in his subjective sighted experiments in utterly different systems & conditions, and have applied his comments (I thought I recognised some of the phrasing) to the sound of your entire loudspeaker? If so, two suggestions, or points. Firstly: take a step back and ask yourself if that is really what you are hearing, or if you have simply read something and it has coloured your opinion. Above all if what you have read is about a single component, not a loudspeaker. No reflection or offense is intended by that -it's very easy to fall into that. One of my design principles is that I trust my ears, but I don't trust my brain not to be fooled, or fool itself.
Secondly -your money, your time, your choice, obviously. But rolling caps is often seen as a magic bullet by those who don't really understand design, or the actual reasons for a given loudspeaker having a given set of characteristics. So rather than spending any money at all -take some time out to learn a little more about design, the different compromises involved, and how these affect performance. You will then be in a better position to decide whether to spend money on capacitors, or to replace the loudspeaker with one that may better meet your requirements.
For reference -I've used many of the same components in commercial designs. I've also used them in the prototype for a more expensive model, the production version of which used the pricier FPP and UPP caps as they didn't break the budget, and it was expected for a speaker in its price range. I couldn't hear any difference.
There is any number of ways to spend $200 and get more out of it than to aimlessly tinker around with fancy replacement caps. A haircut for example would probably make as big a difference to the sound, whether it's your hair or your partner's, or even the dog's.
Scott and Chris have given very good advice I think. Any loudspeaker's sound is the result of a whole system, not that of individually stacked components. Dynaudio obviously have their own, pretty specific system approach, and your sound is the result of that. Changing some random cap (most likely a shunt anyway) will change absolutely nothing (random value tolerances and the cap vendor's bottom line excepted).
In all likelyhood, Dynaudio, as a commercial and competent brand, have pretty much gotten much of what's possible out of the drivers. You can build a different crossover with a different approach (steeper, higher, lower, etc), but you will be trading one set of compromises for another. To do that, you will need to aquire the mentioned measuring rig and a knowledge of crossover simulators (and corssover theory). It might still be worth it, depending on your tastes.
Disabled Account
Joined 2017
I have tried many different caps, coils and resistors in my custom designs. If you have drivers capable of high resolution sonics (we'll call it that for now) but use inferior crossover components; upgrading the crossover will make a big difference. I have done A-B comparisons using clip leads or sometimes a quality switch and listen to my most familiar recordings. Higher quality crossover components do make a significant improvement in resolution. Now, everyone chiming in here have valid points but don't let that stop you from experimenting if that's what you want to do. I always experiment and have boxes full of spare parts; that is the fun part for me.
Hi kawihornet,
What type of resistors would you recommend?
Thanks for the recommendation!
