I simulated this amp, looks stable. Damir knows what he is doing.
I suspect pcb or component problem.
Thimios, can you measure the VAS idle current ?
Problem solved with Valery's suggestion.
Good catc Valery!
I think is the end...
Coming soon.
Now i prepare the fft test.
Cherry compensation is difficult. It is highly depend on capacitance input of output transistor. In Symasym amplifier, if output transistor change to 2SC5200 it become oscillated. Change the value of cherry compensation resolve the problem.
Damir, maybe you should try exicon latfet model of Ian Heglun in this forum. Maybe it need change the value of gate resistor and adjust the cherry compensation.
VR31=1.3v
Damir CFA120W +/-50V FFT
+/-50V
bias=130mA
Last picture the sound card loop test for comparison.
+/-50V
bias=130mA
VR23=750mV
8mA
Too much for TO92 device. Try to set ca 4mA. ( 820R R14,R18) and go back to cherry comp. recheck bias.
With my pleasure but not now😉Too much for TO92 device. Try to set ca 4mA. ( 820R R14,R18) and go back to cherry comp. recheck bias.
I used exactly exicon latfet model of Ian Heglun in my simulation.
If not OITPC I will not support anymore.
So place your suggestions🙂I used exactly exicon latfet model of Ian Heglun in my simulation.
Are you in agreement with the LKA, lower VAS current?
Yes, VAS current should be between 3.5 and 4 mA. Decrease R14 and R18 to 560R and check.
You can try also without C8 and C11 (paralleled to VAS emitter resistor).
Ok,this will be a job for this afternoon.🙂
Here is simulated LG with C6 connected and with C6 not connected.
ULGF does not change but PM and GM drop dramatically.
It could be that Exicon latmosfet need higher value for gate stoppers, try 680R.
This afternoon🙂Here is simulated LG with C6 connected and with C6 not connected.
Same value for P&N fets?
- Lateral CFA 120W - BSA
