Lateral CFA 120W - BSA
Hello Damir,
what transformer do you recommend for a class A 40W mono block? 2x24V AC with xxxVA?
BR
Günni
Hi Gunni,
This amp will take about 3A per rail with no signal, and you need double at full power.
I would say good choice will be 2x25V 6A, and to be on save side 10A, so 300VA to 500VA transformer for mono or 600VA to 800VA for stereo.
BR Damir
spice makes you see better
It is OK. I am interested about your build.
Ok thanks damir!
Drilled, not perfectly but acceptable.. 😉
Last picture, once again in the UV exposure for completely photoresist removal.
Starting to assembling.
Unfortunately i must start to desolder.
They are wrong polarity placed electrolytis at the offset controller power supply c22, c23.
Small progress but i have many missing parts...
I have 0,22R & 0.33R non inductance.
I have 0,27R wire resistors.
I think that 0. 22R is ok.
I haven't boutique caps for compensation,so i will use multilayer for test.
