Another way to accommodate dual 15s, in this case Altec 416 or 515b:
Hornsolutions Referenz Lautsprecher Frontloaded Basshorn Altec 416 515B_1.jpg97.6 KB · Views: 431
Hornsolutions Referenz Lautsprecher Frontloaded Basshorn Altec 416 515B_4.jpg174.9 KB · Views: 435
Hornsolutions Referenz Lautsprecher Frontloaded Basshorn Altec 416 515B_5.jpg263.9 KB · Views: 409
Hornsolutions Referenz Lautsprecher Frontloaded Basshorn Altec 416 515B_7.jpg56.1 KB · Views: 440
Now that is just plain cool !
What causes that shelf at the bottom I wonder?
One size up:
I was actually just daydreaming of a center channel for the drum set.....I believe that’s it!
That big horn requires some construction work.
Is that your build? I would love to read up on that. I love those large horns. I wish I had a basement here in my new house as I’ve always wanted to build a monster of a horn sub under the floor of the house
My wife as given me the green light to go nuts with a custom speaker build in the formal living room
Very nice!
Seen Paul's Octagon? Too many drivers for this project but perhaps a few ideas there...
http://www.paulwav.com/octagon-2-0.html
No, that horn was custom-built by a German horn manufacturer. They also make the snail horns shown above.
If you want to go crazy, this project by Roberto Delle Curti could be a source of inspiration:
Translated info:
The size of the AUDIO room is 6.95 x 8.70 meters.
The SUBWOOFER horns are built under the floor and have a depth of 1 meter. Each horn is driven by 8 WOOFERS of 47 cm for a total of 16 WOOFERS.
Total efficiency 110 dB / 1W / 1m. Each woofer supports a power of 400 watts for a total of 6400 electric watts. The maximum power that reaches the woofers during the highest musical passages, measured at the oscilloscope is about 60 watts per channel.
Each horn has a length of 9.5 meters and an outlet of 2.2 square meters and reproduce frequencies from 5 Hertz upwards at full power. The outlet is not the one visible on the floor, but the side panels that act as a wave guide, plus the ceiling conveyors must also be considered. The horns are calculated with the side walls for half of the 11 Hz wavelength from the woofers to the listening point.
Very nice!
Paul's Octagon is probably one of the best DIY home theater builds.
Overkill, in the good sense of the word.
For those interested, here's Paul W's Raptor thread.
Came across another, apparently B&C loaded, MTM of French origin:
The horn on those look 👍
They're very good.…. and that horn doesn't even cost a lot and doesn't sound horn-like in any way.
Some of us don't see that as a disadvantage, rather the opposite.The only disadvantage is its narrow dispersion.
- Is it possible to cover the whole spectrum, high SPL, low distortion with a 2-way?
