John Curl's Blowtorch preamplifier part III
Improving the SCP-1, a few ideas
1. Choose a small-size transformer with lowest possible primary-to-secondary capacitance. This will probably turn out to be one which contains an electrostatic shield.
2. Build a sub-enclosure for the transformer only, out of Mu-metal. When the product's complete and you're doing the final final listening evaluations before releasing to reviewers and the public, you can always perform (sighted) tests with, and without, the mu metal.
3. Fit three ferrite beads optimized for low frequency operation, such as LFB formulation from Laird Performance Materials, between the secondary and the diode bridge. One bead is common mode (both wires) and the other two are single ended (one wire).
4. Measure the transformer's secondary leakage inductance in the three most common configurations: 230VAC primary, 115VAC primary, 100VAC primary.
5. Choose modern soft recovery diodes to implement the bridge rectifier, perhaps including data from the "100 mA" columns of the performance tables on pp 106-7 of the Linear Audio article about soft recovery diodes, in your decision making process. Be sure to obtain their capacitance-vs-voltage characteristic, for use in the next step.
5. Use the mathematics of second order linear systems to calculate the appropriate damping resistance, which yields Bessel alignment of the damped resonant network. If you don't happen to remember off the top of your head, here it is: Bessel requires zeta=0.866=sqrt(3/4). Install this damping resistance, perhaps including DC power abatement componentry. You'll need to do this three times, for the three different primary configurations. The three calculated resistances will all fall within a ±15% window, but 15% simply isn't good enough for a definitive statement product at the high end, amirite?
6. Using a battery powered oscilloscope which floats with respect to all grounds in the lab (including Protective Earth Ground), measure the performance of the improved AC-to-DC subsystem. With and without soft recovery diodes. With and without resonance-damping. With and without ferrite beads. With and without mu metal subenclosure.
Whew. I'm tired of typing. That's all for now.
Since audiophile pretension trumps all aspects of cost or "green" here is a really good supply option, relatively easy to implement-
Startout with a Sola type constant voltage transformer.
Rectify its output with an appropriate cap.
Drive a large incandescent light bulb (100W? must be extinct)
Couple that to a solar cell array to get enough voltage and current to drive your circuit.
Encase in a steel box (14 gauge) to keep any magnetic radiation inside.
Complete galvanic isolation with very little ripple (the filament's time constant will filter what the cap doesn't).
Questions to specialists:
John mentioned E-core transformers. If If I'm not mistaken, they are usually build with Iron foils as magnetic chassis. While C-Core are usually ferrite type.
As iron is conductive, that ferrite is not, can't we think that C-core will be more efficient to reduce capacitive coupling between primary and secondary ?
Right on cue. Ferrites are bad.
Where’s Bruno when you need him . . .
There is a lot of CM HF garbage on the mains from all sorts of non audio related consumer stuff and from power line communications networks. Id rather use a ferrite of some description to block this stuff than let it into an amp or pre.
But, how do you do it? Or is that a trade secret?
Type #47 core
-RNM
Many years ago, a colleague at work passed the + lead of a SMPS output reservoir capacitor through one of those small toroidal EMC cores and I will never forget hot it got - you could not touch it.
EMC ferrites generally turn HF energy into heat, leaving the good stuff to go on it’s way.
Hi John,
I recently designed a replacement PS for a old Pioneer SX-1010, I used a TL783 for the + and a LM237KCS for the -ve, I'll post the schematic for you. Dead simple, works fine, listening to it right now. Might not meet the stringent requirements of some audiophiles, so be it, pay more ... to satisfy yourselves.
In the initial testing, the -ve(LM237) was drifting down, it was because of the input series R, if it was increased it would drift with the local 10n film, I changed the local bypass to a 1uF Wima MKS4, rock solid.
Rick
