Open source Waveguides for CNC & 3D printing!
How much are you guys willing to pay? See attached price list for the Scan-Speak waveguide (5" / version-A). CNC from aluminium, black anodized.
@augerpro
Would you mind testing Visaton WG with SB26 textile dome, even with original alu faceplate. Due to smaller dome and surround compared to D3004, if dip is moved higher, that would make a killer budget combo.
edit: another DiyA member used Morel Tweeter with WG148 for a surprisingly good result:
attachment.php
full build: Seas L15RLY/P with Morel DMS30s in Visaton WG148R
If you look carefully its not bigger than mw13, actually I'd say its regular 104mm size... USXX commented on danish forums that simple conical is usually best, and that stac is designed to be wg loaded...
you can also see new 2.5" satori mid - Waveguide that haha
hi guys,
I got some news from High End Munich show...
Both waveguided sb26 and waveguided tw29B should be released in next 4 months.
sb26
tw29
Seems like ~2mm step is required and I'd say estimate a shallow elliptical.
edit: images work, even though forum wont show them.
hi guys,
sb26
tw29
Can't see any of those images.
@Gaga,
Exactly what I thought! Your seems made sense to me!
I think they are only way forward tbh. Did you maybe try "reverse engineering" some of the measured WGs in order to improve your models?
I really see potential in elliptical flare! Tbh,sensitivity is too low for excellent measuring adc.
