Aleph J illustrated build guide
So what you are saying is. My transformer is a bit on the smal side maybee.
But i dont think i have room for two of them.
Just for clarification, I believe 6L6 was saying to parallel the 2 windings on a given transformer and use that transformer for one side of the supply either positive or negative. This should not cause any issues at all. I would not parallel 2 windings from different transformers as that would likely cause some problems. Given that the Aleph J has a limited current output I would think going full dual mono supplies would have minimal benefit compared to an amp with a wider current output range such as F5.
I was just inside my Aleph J yesterday to check it before putting it back into service. I am using 20v 400va transformer - with a clc supply. I measured +-23.7 volts and ac rippple of only 2 or 3 mv. This amp is dead quiet even on high efficiency speakers.
I was running an ACA into a pair of mid sized bookshelf speakers and when I switched to the J it was much more refined, dynamic and musical, which surprised me given that the ACA sounded pretty good. Aleph J is a very good amplifier for speakers that can live with it’s power rating and its output impedance.
I did paralleling of windings of (one) xformer in the past , but only when I was certain ( after visual inspection) that two windings are bifillary wound
in all other cases , I did paralleling after bridges
same case here - either full dual mono , or connecting both xformes to one cap bank , after bridges ..... obviously - each xformer having own bridge(s)
I have done it a few times and never had any difficulty. What I do is to parallel the windings and monitor the line current to see if it goes up after paralleling. Many transformers have primaries that are designed for parallel or series use to accommodate 120/240 volt use. This may not be as common outside North America where we have 120v as standard resisdential voltage. I think it is always better to have the exact specified transformer for the job but as DIY builders we often have to improvise to get the job done.
I looked at mine last night as well and have similar findings as you. CLC supply, 300va - 20v secondaries and left at idle for an hour with lid on and I got readings of 42 degree Celsius on transformer. That's with a bias of 420 and 55 degree Celsius on the sinks in a 4U chassis
@nikko03 I can't tell how big your transformer is but if it's truly 300VA it should be enough.
For comparison, here are 300VA potted Plitron, shielded Antek 3218, shielded Antek 4218 (300va and 400va).
Caliper reading in mm, but board underneath squares should be 1 inch
I measured my transformer yesterday. And it it 110mm rougly the same size as the one on the first picture.
