Is less or more ?
And something else ? What the difference between coaxial driver and full range ? I know that coaxial has to driver in one unit (one tweeter and one mid woofer in one speaker ) .
Is the coaxial unit also easy to use as the full range without requiring custom crossover ?
Calling the 10F a 4” is really pushing it.
dave
Sorry i missed that
The cabinet is the point of interest . See the application note .
Could this Cabinet design work with the prestige line ?
Or i have to use this speaker only ?
I guess the easy answer is no because seas did measurements to conclude to this cabinet design . But it would be interesting if you use the seas exotic cabinet design with perstige full range speaker
You need a speaker about the same resonant frequency. The cabinet functions as damper due to holes separating the two volumes . You can use two holed mazonit panels sandwiched by separators for rigidity, instead .
For simple and easy you could also consider the fame 12-250. If you look in the thread, Steve Creswell showed a nice closed box for that, which he reviewed favorably. Definitely piqued my curiosity. I am a happy 10p Pensil and small reflex box user, so those come strongly recommended.
Yeah any pictures related to that ?
What stuffing did you use inside your 10p and did you use any cabinet coating inside like Acry-Tech Acoust-x?
Am I missing something here? If you are getting a cabinet maker to do the cabinets for you, why the need tor them to be simple? I assume the cabinet maker is a professional so whatever plans you give to him should not be a challenge. Why not use their capacity to your advantage and go for the best enclosure, as complicated it might be?
I will go to a wood worker . No speaker cabinet wood worker .
The wood workers near my place are mostly cutting wood for furniture . So i a afraid that they will not understand perfectly a speaker application design and also apply the ports for cables and also dumping coating .
It is worth it in the long run to get the most out of your driver so a simple cabinet is not going to be good value in the long run.
Any wood worker will be able to help you. Sonically advanced cabinets are not difficult for someone in the field.
What about acoustic coating like Acoust-x ?
Any great speaker design document with measurement and speaker recommendation ?
Damping and wiring are something you should be doing. It is worth noting that some boxes need the damping installed before the last side goes on, others you can just do it thru the driver hole.
If you want simple, as i said earlier, 50-60 litre sealed box with SEAS FA22. Almost any shape. Choose a shape you like.
dave
dave
Every time i loose hope .. You came and save the day . What about coating the inside of a speaker with acoust-x instead of stuffing ?
dave
Don't lose hope! All the advice and all the options can be overwhelming, but once you decide on what you want, go for it. It will be worth it all!!!
Mike
...acoust-x instead of stuffing ?
That has a completely different purpose than the damping in the box. The 1st is intended to damp the cabinet walls. How effective it is at that i don’t know, The damping we are talking about damps the air space.
Acry-Tech Acoust-X 1 Gallon Absorption Coating Paintable Damping Material
dave
You mean something like that ?
Polyester and lambswool fibre fill and wadding from World of Wool – World Of Wool Retail
dave
That is one of the options. It is dependent on the type of speaker you build. For a sealed box you could use that — well teased — to fill the entire box (leave some room behind the back of the speaker.
dave
dave
- Full Range
- DIY full range speaker
