Babelfish M25, SissySIT - general building tips and tricks
Got the Cinemags yesterday, so soon total Sissiness will take over 🙂
My M2s are quite good now after a long run in period, had the house for my self yesterday and played rock at life levels. Dont think I have ever heard and felt Sabbath Ironman (remast. vinyl) like this before. 🙂 🙂 Will be fun to compare to SissySIT.
Hi all,
a little progress ... only a mechanical test. The little screws / washer will changed and the bracket will be sanded and black painted or should it let it silver (alu)? :wave:🙄
The screws (M6 ISO 7380-2 A2 V2A) from the bracket to the heatsinks get also washers, M6 screws fits perfects between the fins of the heatsinks.
preview
And now ... family, tomorrow is a mother day!
Hi ZM,
thanks for your answer!
split washers everywhere
Yes, of course!
though , if you have standard wide case (Modushop? at least heatsinks are) , you'll have trouble with tight space in case , because of L brackets
Yes you're right it is a Modushop but it seems to fit, the rectifer will mounted on bottom in the front or at the front panel.
I think about a extra case for the PS only, so that I can use for other Papa amps.
preview
Another question, is for Iq also possible 1A2 (need not so much wattage for my speaker), thanks?
Assembly of a new Pass Amps case has started:
attachment.php
(First inhabitant will be SissySIT)
Curently working on PSU:
attachment.php
attachment.php
Looking forward to M25 / SissySIT PCBs - have already measured and set aside two pairs of THF-51S / 2SJ201 ... 😀
Best regards,
Claas
OK, on a different computer now, and here I get the same problem ...
Reposting, hope this will work better:
attachment.php
attachment.php
attachment.php
Best regards,
Claas
