cleaning boards
gaborbela use a stiff tooth brush with the alcohol and "scrub" the flux.
Then wash off the residue with clean alcohol and dry with a clean cloth.
Try not to get the alcohol under the electrolytics or into the trim pots.
You might need to do this a few times.
I usually solder the resistors and quick connects first and then thoroughly clean my boards. After that I solder the caps and transistors.
Hope that helps.
Hope that helps.
Finished the boards and cleaned up the power supply. It’s dead quiet. So much so that I wouldn’t even know the amp was on. While playing music, it almost seems like something is missing but in reality it is not. I can hear the details and separation of the voices and instruments. The bass is tight and makes the Tang Bands W8s have a fuller sound. I will report more of my impressions once I listen to it some more.
The amp itself uses two SMPS600 from Cresnet (I highly recommend) along with an addition cap bank per SMPS. For the input, I’m using XLRs converted to single ended by Cinemags 15/15b transformers.
Hi Bao.
Congrats. Have fun with the v4h.
One question, I don't see a connection to SGND. Is it connected underboard?
Hi !
Where did you get this nice enclosure from, can't read the brand
Thanks, very nice work
JM
Harry, the extra capacitors are Mundorf Mlytic AG 4700uf.
Shaan, yes all the wiring is underneath the boards as well as the subchassis. Thank you for the wonderful amp and support!
JM, the enclosure is based on a Pioneer home theatre receiver. I made the subchassis to mount the heat sinks as well as the front and rear fascia. The subchassis also hides the wires. The front faceplate was made to match the Integra receiver. It has lettering I made; however, it says the old amplifier modules I had in there.
Bao
Bao
GB3 Update
CitizenKane - 6 PCBs
delange - 4 PCBs + 4 Pair MOSFETs
gusto142 - 2 PCBs
samratsarkar - 2 PCBs
md_Stryker - 2 PCBs + 4 Pair MOSFETS
outtek - 2 PCBs
supernet - 2 PCBs
anilrao - 2 Modules
janho12345 - 2 PCBS
I will start sending invoices to GB members from tonight. Anyone interersted can still join this GB.
Thanks,
shaan
gusto142 - 2 PCBs
outtek - 2 PCBs
supernet - 2 PCBs
anilrao - 2 Modules
janho12345 - 2 PCBS
Thanks,
shaan
GB3 Update
CitizenKane - 6 PCBs - PAID
delange - 4 PCBs + 4 Pair MOSFETs - PAID
gusto142 - 2 PCBs - PAID
samratsarkar - 2 PCBs - PAID
md_Stryker - 2 PCBs + 4 Pair MOSFETS - PAID
outtek - 2 PCBs - PAID
supernet - 2 PCBs - PAID
anilrao - 2 Modules - PAID
janho12345 - 2 PCBs - PAID
force of 1/2 - 2 PCBs + 4 Pair MOSFETs - INVOICE SENT
Rick G - 2 PCBs - INVOICE SENT
PCBs ordered. Expecting delivery by first week of April.
Thanks everyone for your interest in PeeCeeBee.
shaan
p/s - New members can still order PCBs if interested.
shaan
GB3 Update
Rick G - 2 PCBs - PAID
GB3 Update
force of 1/2 - 2 PCBs + 4 Pair MOSFETs - PAID
Hello Shaan,
I've been looking at the schematics and BOM for the V4H amp (in anticipation of the PCB's). One question comes to mind: doesn't the amplifier need a zobel network at the output?
Hi Delange.
PCBs have been shipped from the fab already and will reach me in a few days.
The v4h has two zobel networks at the output. The two 10R+100nF segments.
Hi Delange.
Thank you for the update on the PCB's.
In regards to the zobel network, I don't know how I missed that one... 🙂
What about an inductor in parallel with a resistor; isn't that required at the output?
- Group Buys
- PeeCeeBee V4H GB
