Pavel,
I might be wrong, but the gerber file included in the page you refer seems to be in not ok condition, meaning that if you get uploaded the file to any pcb manufacturing house what you can see is a big working frame which includes the board inside. I don´t think the gerber is well generated. Would you mind please to take a look into it ? big thanks
cheers
Pepe
I didn’t have any issues getting boards made at JLCPCB with the gerbers from puredsd.ru.
Yes, there were no problems with JLCPCB. I will check with other manufacturers and correct the error.
Corrected, checked. Clear the browser's cache and download http://puredsd.ru/mainboard.zip again.Thanks Pavel
cheers
.Pepe.
Thank you for noticing the error.
Pavel,
Is the black output audio transformer from the BOM now recommended over the old yellow one? They have different specs... It is better sounding?
black from BOM: R3 Jiayin 10K:10K permalloy audio transformer pre input cattle single end turn to balance signal isolation-in Transformers from Home Improvement on Aliexpress.com | Alibaba Group
old yellow: 2PCS / 10K:10K permalloy audio isolation transformer, balanced and unbalanced conversion audio isolator-in Transformers from Home Improvement on Aliexpress.com | Alibaba Group
Best regards,
Dejan
Best regards,
Dejan
Black and yellow sound the same. This is the same model R3.
Yellow a little brighter. But the difference is so small that it is noticeable only with fast switching. Black made better quality.
Hi Pavel,
is there a resistor type better then rhose in BOM?
Any news about the company that can sell complete populated board?
These Jensen copy are better?
R1 imitado estadounidense ares Jensen audio vaca aislamiento 10 K: 10 K permalloy fiebre senal ganado en Transformadores de Mejoras para el hogar en AliExpress.com | Alibaba Group R1 imitado estadounidense ares Jensen audio vaca aislamiento 10 K: 10 K permalloy fiebre senal ganado en Transformadores de Mejoras para el hogar en AliExpress.com | Alibaba Group
No, R1 is not suitable for DSC.These Jensen copy are better?
Need R3.
I did not have the opportunity to compare the sound of all resistors that are worthy of attention. Based on my practical experience, the PFC-W1206LF tantalum resistors are a good option.is there a resistor type better then rhose in BOM?
I was offered to open production at the plant allo.com. I can re-talk with allo.com for production and direct sales.Any news about the company that can sell complete populated board?
R3 - Aliexpress.com: Comprar R3 Jiayin 10 K: 10 K permalloy audio transformador entrada pre ganado solo extremo vuelta para equilibrar la senal de aislamiento de Transformadores fiable proveedores en Zhifeng D electron Store
R1 - R1 imitado estadounidense ares Jensen audio vaca aislamiento 10 K: 10 K permalloy fiebre senal ganado en Transformadores de Mejoras para el hogar en AliExpress.com | Alibaba Group
Thank you.
BTW I'm looking for the last Amanero firmware for native DSD512?
TIA
Felipe
TIA
Felipe
74AHCT595PW
IBS Electronics
Search results for: '74AHCT595' | IBS Electronics
Whether they are the older versions or not? I don't know but I have some on order anyway.
FWIW The data sheet is dated July 2012
IBS Electronics
IBS Electronics
This is in the wrong package, TSSOP16.
- Digital Line Level
- Signalyst DSC1
