Here is ‘down’ on. Because, when you enter a room in the dark, it is more natural to wave your hand downwards to find the light switch.
Thanks soooooooooooooo much. One problem with this build is that there is just too many versions and finding exactly the right information is hard to find. Thanks again!
ACA v1.6 problems.
Hello everybody. Tim in Denver. I just finished building the ACA v1.6 after it plays for a few minutes starts turning off then after a couple seconds back on then off again repeat. Is there anybody in Denver area that would be willing to look at it, help me out. I am not a tech just like good sound.
Hi all, anyone know if the ACA 1.6 chassis is available to purchase direct from Modushop at the moment? the link seems to be coming up 'not found'
Quick thought... are you using the correct power supply?
What you describe could be a symptom of the power cycling on and off.
No mistake, just a different method I think.
And I am still not quite with you yet. So let's try something else.
Unsolder one end of R7, measure its resistance. (Should be 10k)
Next unsolder one end of R5, measure its resistance. (Should be 100r)
Leave them out of circuit for the next test.
Now put the Black meter lead on the ground wire.
Measure the resistance from ground to S, then from ground to G and again from ground to D of Q2.
Let us know the results. Alan
Sorry for the wait, I've got a pretty busy week !
Here what I got :
Unsolder one end of R7, measure its resistance. (Should be 10k) : 10K
Next unsolder one end of R5, measure its resistance. (Should be 100r) : 100r
Measure the resistance from ground to S : 520r
then from ground to G : 0r
and again from ground to D of Q2 : 520r
I will admit I am still having some difficulty reconciling some of the measurements. I expect it will become clear once we know what the fault is...
That is a very odd result.
There should be no connection from ground to Q2 G with R5 lifted. Only explanation is a solder blob or wire strand shorting to the heatsink?
There is little point trying anything else, It Is time to take it apart and inspect the rear of the board. Then do some out of circuit checks on the 'transistors'.
Alan
then from ground to G (Q2) : 0r
Alan
Alan
I will check that tommorow and get back to you.
I'm a first-time builder and have a question I'm hoping can be answered here. Has anyone had an issue where a potentiometer will not bias? One of the potentiometers displays on my dmm as 25.5v no matter where I set it. The other one behaves as expected. Needless to say, the amp isn't working. Powers up, leds light but no audio output. Not a surprise given my lack of soldering skills.
Thanks,
Gary
Thanks,
Gary
Thanks,
Gary
You could check that the pot is adjusting resistance with power off and your DMM probing the relevant connections. That should rule in/out whether you've flowed solder on to the pot's connections satisfactorily.
Gary - are you measuring the bias as shown in the guide and it’s always reading the same thing? Do you have an autoranging meter or one where you have to choose the range? If the latter set to DC volts 200.
Gary,
You have probably answered your own question, 90% chance it is a poor solder connection.
First make sure all the components are in their correct place, easy to mix up some resistors. Make sure that Q3 and Q4 are the right way round and that the capacitors are the right way round too.
If you post some good pictures we can take a look as well.
Alan
Edit, where do you get 25.5 volts from? What power supply are you using? Please measure the voltage at the V+ pad on the board to the GND pad.
Alan
I'll try that. Thanks very much.
I am measuring the bias as shown in the guide. It's always 20.5 My meter is not autoranging. It's set to DC volts 200. The bias does measure correctly in the other channel. Thanks.
I'll check all that you mention. The voltage measured is actually 20.5. I should also mention that I did search the thread before posting. I found that someone else had the same problem. What resolved the issue for him was not applicable to my amp. I'm sure I soldered something badly. In addition to what you suggest I'm going to try reflowing anything that looks suspicious. I have to say, this feels like a short somewhere. It's definitely down to something I've done wrong. Thanks for the response.
Gary,
Alan
Thanks to the help here I've discovered the problem with that potentiometer. Somehow one of the legs got broken off after insertion. The leg is completely missing in action. Careless handling on my part, no doubt. It wouldn't surprise if I've inadvertently caused other damage as well. I'm considering simply purchasing another parts kit. Thanks again to all who responded.
- The diyAudio Store
- Amp Camp Amp Kit 1.6/1.8
