Current Feedback Amplifiers, not only a semantic problem?
We can restate the canonical feedback forms in plain English as:-
A current output amplifier using voltage feedback (example would be constant torque drive of a motor or a current drive for a loudspeaker)
A voltage output amplifier using current feedback (generally in audio circles this is what we call a CFA)
A current output amplifier using current feedback (rarely used)
A voltage output amplifier using voltage feedback (the most common type of audio amplifier - tube or solid state).
No doubt I will get an abusive email or PM about this from MK and others on this thread but its ok because I can take it.
No hate mail from me, but IMO this is not "restating" but "reinventing". Why would anyone need to "reinvent" anything when it comes to the four feedback topologies is one of those impenetrable mysteries of life 😀.
Nothing intentional - just easier to get the concepts across 🙂
That would be a good thing; unfortunately I don’t see how these new definitions would be equivalent with what Black taught us, a very long time ago. Hence the “reinvention” as a useless exercise 😀.
The next step would be to put these two set of definitions (Black and Bonsai) on two columns and show how they map, but I’ll stop short of asking for this, I’m not that of a cynical SOB 😀.
Sorry Osvaldo, that text is misleading.
To justify my position on this, I refer you to the 4 canonical feedback forms - these are normally described in terms of 'shunt' and 'series' output and feedback.
You have discriminate clearly and decisively between CURRENT OUTPUT (aka 'constant current output') and CURRENT FEEDBACK AS Jan has mentioned. We can restate the canonical feedback forms in plain English as:-
Another form to say what I said above. And combination(s) of them.
Surely my English is not too good.
Let’s approach the subject of this thread a little differently. Around feedback loops, there are both voltage and current gains. One way to evaluate them starts with inserting a signal into the loop without disturbing impedances or component biasing. If two specific signals traveling in the forward direction around the loop (one immediately after the insertion point and the other immediately prior to it) are non-zero, then the signal gain and feedback are finite and non-zero. The following text and accompanying schematic provide a general example which supports and elucidates these claims.
Consider any amplifier that has inverting and non-inverting inputs and a single ended output. There is an impedance rd between the inputs. We could describe the output stage as a voltage source vo in series with ro or equivalently, a current source io in parallel with ro. And we could state that vo is equal to the unitless parameter A times the difference between the input voltages, or alternatively that vo is equal to the product of an impedance Z and the current flowing into an input, where Z = A · rd.
Let’s work with the first of each option pair. From the perspective of the inverting input, the combination of the output stage and feedback network looks like an impedance zf in series with a voltage source equal to vo times an attenuation factor β. Analysis of the accompanying circuit loop gives us:
a current gain of ir/if = (β·A+1) · rd/zf
a voltage gain of vr/vf = zf/rd + β·A.​
There is less current than voltage gain when zf/rd is greater than one, but more when that ratio is less than one. The gains are equal when zf equals rd.
The situation is the opposite for feedback. Decreasing values of zf/rd lead to growing amounts of voltage feedback, an intuitively satisfying result. But increasing values of zf/rd mean that a smaller portion of ir is leading to a larger portion of if - that is, current feedback is rising.
The application of the forgoing analysis to the main subject of this thread should be clear.
I'm just listening to genesis through a CFA.
And bathing in the light of a LED (quantum well).
Both debated technologies perform well , We can continue to debate them.
As a "pitchfork villager" , it is magic.
CFA controversy even triggered magic VAS's to accommodate magic
slewrates.
The semantics are positive ., may the arguments continue. 😛
OS
In common base mode, the base is at AC ground potential, if not DC ground potential. Since this is generally not the case with CFAs, no, I wouldn't say that.
I think seeing the CFA device(s) when the F of CFA is working, that means in a circuit in closed loop configuration otherwise letter F has no meaning here, as being in common base mode is fully misleading.
The CFA input stage is always described as a buffer (a voltage follower in series with a low impedance). It is sometimes said to be a kind of AC voltage regulator. The current it delivers is controlled by itself depending of its emitter load. In common base mode, the current is received, determined outside of the device.
Note that Cyril Mechkov complained about the lack of references to the devices mode in the litterature about CFA : What is the truth about the exotic current feedback amplifier? Is it something new or just well known old? Is it really a current feedback device?
But what was my surprise when browsing through reputable sources? I noticed that instead of being made related to the classical tricks widely used in transistor circuits, the current feedback amplifier is presented as something completely new. I have not met even a hint of the existence of such famous circuit ideas like "common-base" and "common-collector" configurations, "dynamic load", "bootstrapping", instead, I read direct statements like "the inverting input is its low-impedance output terminal"
OK, let's have a conversation. I answer your question, and you respond to Post 2548.
Sorry, your reasoning is probably right but I do not see its aim.
