very nice build !🙂
i have built mine with THF51S and CCS loading at 2.1A 30V ,
much balls than my previous Sony 2SK82 amps but mucho heat too
some will say "fugly"
EL Reino - it would be nice if you add exact schematic and few words more about some parts used
I see that you're using Iron in output , but can't be sure is it choke or xformer
take care to use split washers on all bolts in thermal arrangements - everything bolted to heatsink , same as on Graetz bridges
hi guys, sometimes i got a ploc plug in my speaker as i have no resistor to discharge the output cap , what is the usual value for it ? don't remember if it is 200K or 200R ? 😕
I use 100R.
Oh.... What nice!.... Wonderful
Thanks Jama, nice to hear from you!...
Finished a l’amp with pencil speakers a while ago for my daughter.
2sk60 based
Superb Cool L'Amp build Bravo 🙂
What is the bulbs model , voltage and power rate ?
Could we find them from ?
Found it: The resistance varies from 35... 45 ohm for a single, depending setup.
Amazon.c..: GE Lighting 73788 Medium Base General Purpose PS25 Light Bulb, 130-Volt, 266/300-Watt
I got a couple spare...
2sk60 based
I love this setting. Good looking amp with a tasteful hipster stand!
Thanks Asanden
Is not 120 V version....do You try with 3 bulbs in paralell ?
Extract from Mr. Rothacher article :
- L'Amp: A simple SIT Amp
