Cartridge dynamic behaviour
Just an academic exercise -- inductance vs excitation level for the Shure M78 and Audio Technica AT4540ML at 10kHz, 10uV to 100mV (not a lot of useful info until 30uV):
Just one more, I popped out the Grado Blue1 from my nieces setup -- high DCR and low inductance:
Thank you for these, jackinnj - the method looks very plausible and I don't see a flaw so seems real to me.
Lots interesting to comment on, but the first is that different carts show different levels as to the turning point for deviation from ideal inductive behaviour.
As a first look, I'd guess this has to do with excitation flux becoming a greater percentage of total flux change with smaller signals. But that would be true for small flux changes where the source was the waggle of the generator too. It reminds me of what got me in to the concept of this loss mechanism a time back now, but your 3577a is a nice piece of kit to explore it with.
I'd venture that reciprocally, a cartridge as a generator would show the same profile, which being non-linear with level, would effectively behave as an expander?
LD
what confuses me is that the audio technica has a laminated core and the Shure does not.
At first glance, I think this could be an excitation issue, a material property, rather than eddy current.
Can you verify the accuracy of the measurements below 1 mV? Maybe with a reference inductor? I would think noise etc. would be a limit at those low levels.
It's a HP3577A, check it out it's way cool. What makes you think a reference inductor, with a similar core material, wouldn't show the same issue?
LD
Demian, will do tomorrow. As always your advise is most appreciated.
HP3577 is a wonderful instrument -- state of the art in 1984 with dynamic range of 100dB, but as the upper freq was less than 200kHz for these measurements I used the AP. You can buy an HP3577a with the S-parameter test set for a few hundred dollars in the US.
I have used the 3577. However signals below 1 mV mean a lower SNR. The lower SNR can compromise the accuracy. Perhaps a capacitor with a similar reactance would be a valid test. What the plot shows is the reactance diminishing as the signal goes down, and at about the same rate for several cartridges. That seems quite backwards.
Another way to see what happens at low levels would be to measure the change in self resonance with level.
That's how the hypothesis that inductance is level sensitive for small signals started. An observation that cartridge LCR resonant f apparently correlates inversely with test track level, and a subsequent attempt to reconcile results.
And the 3577A is well capable of measurements at hand.
LD
I should add, it's not that the LCR resonance is of concern. Rather, that effects might be reciprocal and so affect output of the generator at small signal levels.
One might hypothesise a level sensitive f response, for example......or a non-linear amplitude response, such as expansion...…….
LD
If it were an air-core we wouldn't have to worry about the B's and H's.
The HP3577 takes a long time to resolve and the averaging methodology is not ideal for this type of measurement. Since I am looking at the impedance at 10kHz and 10Hz I decided to switch to the AP and use 2-channel measurement with 300 ohm input impedance.
How do you explain the fact that the current noise of a high Ib bi-polar op-amp easily shows the LRC resonance of the coil as specified on the cartridge data sheet? I've measured it and posted the pics here years ago. The op-amp was Ib comped so we're talking nV of excitation. Same was true of the self noise as measured with a FET op-amp.
That C is somehow not what it seems to be ?
LD
2nd edit: here's a blast from the past for tonearm resonances calculated impedance
LD
If the arm is typical hollow tube .... you can dampen these with little to no other side effects 🙂 By injecting expanding foam sealant inside the arm tube. yes, same as used in insulation. large cell/small cell/density can be obtained. Very light weight evenly distributed end to end.
Amazing affect on sound. smoother, not so rough sounding. IIRC.
THx-RNMarsh
