Dear Vit123
Pistolero has 2.6 and I am looking for 2.5 because I have Lundahl 1684 wich I would like to try. If someone has the capabilities to produce 2.5 please let me know.
Greetings
Greetings
Hi vit123 - - - and Everyone else- has anyone heard from hiddenpilot = Alexey lately or does anyone have a way to get in touch with him? I paid my $ 270.00 almost 3 months ago, and I am very worried ... it looks like hiddenpilot- Alexey took my money and disappeared. I was a little hesitant to send that much money to Russia - but there was no indication that there might be a problem.... others received their Boards and vit seemed like a really great guy - so all seemed fine but - I have sent messages 3 times and each time Alexey has responded and said he would mail it out in a day or two - But nothing has ever happened and no tracking number was ever sent as Alexey had promised. But we are coming up on 3 on three months ... and I only hope this is just a big mix up - or he is just really busy or something. 270.00 dollars is a lot of money to me - so I am hoping vit or someone is able to talk to Alexey - hiddenpilot for me . Best Regards , Dean Halleck
Hi Dean,
I've just talked with Alexey about your shipment. He will check everything and give you feedback.
Alexey is an honest person, I am sure that it is a misunderstanding or his mistake.
Sorry for this situation.
Please keep me informed, of course i will help.
I suggest post all info here (not in PM), so the situation will be clear for all interested parties.
Hello Dean,
I'am so sorry for this situation. Indeed, I've not sent your DSC, due to the high working load.
Once again I bring my apologies for this.
I will compensate you for $50 for lost time.
I've sent you PM with additional info, please check.
Best Regards, Alexey Galkin
Hi, Dean,I am hoping vit or someone is able to talk to Alexey - hiddenpilot for me . Best Regards , Dean Halleck
I sent you a link to the PM, there is a photos with your order kit and the delivery address form. Please check your order kit and shipping address. If all is well please confirm it. I will immediately send you the order after your confirmation.
Thank you,
Alexey Galkin.
As Pavel announced new version of DSC with onboard reclocker, he gave me his own image of Botic for testing...
Main features:
1. 4.9.199-rt kernel with Miero Botic driver. NAA preinstalled.
2. Root file system from RAM.
3. Only the most necessary is left, everything else removed. SSH is temporary available (root:root). As only NAA installed, HQP must be used as player.
I must say that it is much better than my own build. 🙂 As agreed with Pavel, the image is available for testing (see README.txt included in zip for HOWTO)
botic_naa(ppy) v1.zip - Google Drive
Today I was laid up so spent some time on my DSC project and tried to install Pavel's stripped-down botic software but I must be doing something wrong as I couldn't get it to boot.
The BBB is currently running Vit's version of botic and all seems well; I'm currently running just the BBB with nothing plugged into it.
I set the microSD card up with a FAT32 primary partition and unzipped the contents of the download onto it. Here's a listing of what's on the uSD;
Following the README instructions, I edited the network config with my home network addressing.
I inserted the uSD into the BBB slot, held down S2 and applied power. The power LED lit but nothing else happened.
Any ideas of where I've gone wrong?
Two errors:Any ideas of where I've gone wrong?
1. Files from the archive are written to an empty SD FAT format.
2. The partition on the SD disk must be active. This is the easiest way to make a free utility MiniTool Partition Wisard or the diskpart command How to Set Active Partition on Windows - Info | Remo Software
Maximum input voltage for LDO
It has been awhile since I purchased my kit. At that time I had access to the PDF manual, but now permission is required and I haven't heard back from Alexi. Can someone tell me what the maximum allowable input voltage the LDOs can dissipate safely?
Try this link: DSC2 2.5.2-2.6.2 - Google Drive
The chip takes up to 20V, but the caps are rated for 16V.
Thank you!
I have a BBB connected to a Twisted Pear Hermes+Chronus combo. Right now it is connected to a Buffalo III ES9018 dac. The BBB is running botic and everything works fine running squeezelite.
I have bought a DSC 2.5.2 which I'd like to use instead of the Buffalo. Can anybody point me in the right direction of what I need to do to end up with a working NAAplayer on the BBB? I have tried to follow the instructions for Ian's McFifo installing the davinci kernel on an SD card. But I do not seem to be able to ssh into the BBB anymore (in fact I don't think it boots properly from the SD cared) and hence cannot really figure out what goes on?
Many thanks in advance.
Giulio
Giulio
Anyone in the US willing to finish the build for me? I am struggling with both time and knowledge. I have all the parts that are needed just need help in connecting everything up in a case with Hermes/Cronus/BBB setup.
I am sorry if this is out of place, but I am looking to buy a DSC kit if anyone has one laying around. Either finished project with Amanero or BBB or a unfinished kit but with all components included. I have been trying to get hold of some of the people who posted on here that they were selling, but no replies so far. Hopefully someone can help me out
Throw a PM my way if you can help.
Can anybody explain why this thread has died and the links on how to create an image for the BBB are no longer working (they require a google login, but nobody reply to the request to be admitted to the group of user)? Anybody?
Yes, GB is really closed. But here Signalyst DSC1 you can get support.Anybody?
What firmware BBB would you like to receive?
There is a firmware version on my site http://puredsd.ru
Or this minifirmware http://puredsd.ru/botic_naa(ppy) v1.zip
If any of you want to sell a 2.5.2 board let me know ( I want to keep it as a spare board for my system).
- Group Buys
- Official GB for DSD DAC Signalyst DSCv2
