This is the usual misunderstanding about this output stage circuit that will come out again and again, forever again.Note: The two common collectors at each output would not introduce the typical nonlinearity because of the general feedback which will make the operational amplifier "switch" the transistors (go through zero) without a problem because the feedback is after the transistors and wil make the amplifier follow the shape of the voltage.
The feedback in this circuit DOES NOT work as you think.
This output stage is just terrible. It has a gross amount of distortion that makes it useless for HiFi audio. And there is no way to improve it.
Yes, it will never go away........the transition through the dead zone takes a finite time, and during this time the loop is broken while the opamp desperately tries to slew to the new output value.
This leads to unavoidable and large cross-over distortion.
You can try to minimize it with a very high slew rate opamp, or by using at least one diode in the bias to halve the transition region, but it will never go away.
Jan
If 0.0008% at 1vp is not yet enough, what you think it should? See the spec of AD844. The open loop frequency is adjustable from 12kHz and over by adding a resistor on TZ if necessary.
If 0.0008% at 1vp is not yet enough, what you think it should? See the spec of AD844. The open loop frequency is adjustable from 12khz and over by adding a resistor on TZ if necessary.
What I don't understand is the reason for creating a hole in the boat and then discussing the ways of plugging it, assuming it's pretty easy to avoid creating this hole in the first place.
Why don't the author bias the OPS properly?
THD doesn't mean too much by itself. Especially in a simulation. Distortion in the crossover region creates countless high order components, resulting in bad intermodulation.
Valery
