What To Do With Those 2SJ28's
I watched the video's but did not hear any news about the V-fet SE amplifier. I do hope it is coming.
Circuits are still being designed, with several candidates. They all
occupy 4 TO-3 holes per channel on a bar which fits on the larger sinks
in the store.
I have a couple things to wrap up, and then you can expect kits early 2019.
Last news 😀
What to Do with Those 2SJ28's ?
Build a new class A of course 🙂
Get fews "new" ones to test , JS and JD-33 grade from vintage Sony Vfet amp.
My luck was find fews used 2SJ28 in swap meet from Mr. J Didden " Linear Audio " magazine director.
Sunday evening if free time I do vfet's test's and open boxes with two medium horn's
who is "the new brick's" for 3-voices bi-amplified system build.
Heavy weight Technics tourntable SL-7 included 🙂 Greetings
The design for the new DIYaudio VFET kits uses one VFET per channel.
The N channel and P channel VFETs have separate artwork, and slightly
different performance.
Each channel goes onto a bar similar to last time which holds 4 TO-3
devices and mounts on the DIYaudio store heat sink hole pattern.
The output stage is a follower, and has a socket for different front ends.
Availability should be March or so.....
:cheers:
Great News!
The magazine page attached looks like an SIT amp with an output transformer. Are you going to make one like that? 🙂
TKS45F323 SIT 😀 is much easier to discover a meteorite in the house garden.
Esoteric & rare & exotic & cost new was ~ 570$ one pcs.
