What is wrong with TPA3255?
Would it be possible to do the same test with a board where you have replaced the power line decoupling capacitors with better ones? That would show how important the quality of the power line decoupling capacitors is.
What exactly do you call power line decoupling caps?
The measured audio band ripple on the supply rails is mainly determined by the decoupling electrolytics on board, their capacitance and ESR. MLCCs with several uF with their higher impedance at audio frequencies do have little effect here.
He is writting about the decoupling caps near the chip.
normally its recommended low esr and about 2220µ/63V is enough.
the YJ use elna or sanwah 4700µ/63V (100) labeld. look at the pic(original board...first switch on)
as i wrote i measured after weeks of operation no esr and the sound is better with new caps 😉...maybe because of the noisy regulator (LM2575)
As requested by FF at post #636😉😀
LRS 150-24....28,7V set
i try a loop test with a burst of 40Hz, periode is 200ms, 1 Cycle. i try 800mVrms in or 1300mVrms into the amps input. at 4R load its more visible. first test did with 8 R.
original amp and caps.
pic 1 8R 1300mVrms in
pic 2 8R same but single burst view
pic 3 4R 800mVrms in
pic 4 4R same but single burst view
pic 5 4R 1300mvrms:devilr:
pic 6 4R with 2 cycles 800mvrms...omg
pic 7 4r with 2 cycles 1300mVrms..ooooomg
...continued..
  • LRS150-24_40hz_4Routput_1Cycle_200msperiode_1300mVrms input burst_originamp_1.jpg
  • LRS150-24_40hz_4Routput_1Cycle_200msperiode_800mVrms input burst_originamp_2.jpg
  • LRS150-24_40hz_4Routput_1Cycle_200msperiode_800mVrms input burst_originamp_1.jpg
  • LRS150-24_40hz_8Routput_1Cycle_200msperiode_1300mVrms input burst_originamp_2.jpg
  • LRS150-24_40hz_8Routput_1Cycle_200msperiode_1300mVrms input burst_originamp_1.jpg
  • LRS150-24_40hz_4Routput_2Cycle_200msperiode_800mVrms input burst_originamp_1.jpg
  • LRS150-24_40hz_4Routput_2Cycle_200msperiode_1300mVrms input burst_originamp_1.jpg
other board (amp6) with GPD caps...quicker but with less juice
just 4R output
pic 1 800mVrms in
pic 2 same but single burst view
pic 3 1300mvrms:devilr:
pic 4 4R with 2 cycles 800mvrms...omg
pic 5 4r with 2 cycles 1300mVrms..ooooomg
the smps is directly connecte no additionaly caps are installed! (for the post before too)
  • LRS150-24_40hz_4Routput_2Cycle_200msperiode_800mVrms input burst_amp6_2.jpg
  • LRS150-24_40hz_4Routput_2Cycle_200msperiode_800mVrms input burst_amp6_1.jpg
  • LRS150-24_40hz_4Routput_1Cycle_200msperiode_1300mVrms input burst_amp6_1.jpg
  • LRS150-24_40hz_4Routput_1Cycle_200msperiode_800mVrms input burst_amp6_2.jpg
  • LRS150-24_40hz_4Routput_1Cycle_200msperiode_800mVrms input burst_amp6_1.jpg
playing around with the original board/caps i found something interesting:
i set the periode smaller= 40hz burst with 600mVrms but the periode of this burst is shorter. 100ms... so i can see the "recovery time" for the smps is not really existing 😀
+ there is an overshoot ! this is not happend with the test setup before
  • LRS150-24_40hz_4Routput_1Cycle_100msperiode_600mVrms input burst_originamp_overshoot_1.jpg
  • LRS150-24_40hz_4Routput_1Cycle_100msperiode_600mVrms input burst_originamp_overshoot_2.jpg
does high frequency burst the power supply? yes....
4R load burst is 5 cycles, periode is 20msec, 800mVrms in the original amp/caps
pic 1 6khz
pic 2 same but single view
pic 3 12khz
pic 4 same but single view
pic 5 16khz
pic 6 same but single view
pic 7 +8 is the 1 cycle burst
..continued...
  • LRS150-24_6khz_4Routput_1Cycle_20msperiode_800mVrms input burst_originamp_2.jpg
  • LRS150-24_6khz_4Routput_1Cycle_20msperiode_800mVrms input burst_originamp_1.jpg
  • LRS150-24_16khz_4Routput_5Cycle_20msperiode_800mVrms input burst_originamp_2.jpg
  • LRS150-24_16khz_4Routput_5Cycle_20msperiode_800mVrms input burst_originamp_1.jpg
  • LRS150-24_12khz_4Routput_5Cycle_20msperiode_800mVrms input burst_originamp_2.jpg
  • LRS150-24_12khz_4Routput_5Cycle_20msperiode_800mVrms input burst_originamp_1.jpg
  • LRS150-24_6khz_4Routput_5Cycle_20msperiode_800mVrms input burst_originamp_2.jpg
  • LRS150-24_6khz_4Routput_5Cycle_20msperiode_800mVrms input burst_originamp_1.jpg
4R load burst is 5 cycles, periode is 20msec, 800mVrms in the amp6 changed decoupling caps = GPD
pic 1 6khz
pic 3 12khz
pic 5 16khz
good night
As you can see, it is not much important if you have 1000uF or 10000uF. 😀
The overshoot is totally normal and will rise with more capacitance
You may add 500000uF, that should help at low frequencies but will increase overshoot if long bursts are run. (If the supply will start)
hi doc:wave:
thank you for your feedback. i will try some extra caps.
as i can see on the pics there is no marcant event happend that can be markeble for SQ between the original and the new caps. in real life it is.....any hint to see that?
