B1 with Korg Triode
OK. Board is 5.5" x 3.25" mounting holes 5.0" x 2.75"
:cheers:
Excellent clear design and confortable space for all components , values writen on the pcb help avoid mistakes ,save time as well.
For amateurs who like triodes light glow on the B1T chassis front is easy to make small adaptor with perfored board etc.
Thank You very much Mr Pass :santa:
My life is better with audio constructive hobby
Compared to initial schematic not all resistors is the same for example 3x 332K and 2 times 33.2K only one 7.5K ?
Where is two volume potentiometers soldering pads, source selection on the prototype pcb ? Oh ok is simplified version.
Not two 9.1V zener's ?
If one channel have 2x1000 uF and one 2200uF total of the big audio section caps is 6 pcs not 5.
Any reason for all changes ? Kindest regards 🙂
Yes, I also like the FW very much. I assume that the very large area of cu on FW PCB is the ground plane? ...the FW layout is for two mono pots for volumen? …..that is quite special. I would probably use a stereo pot anyway…...
B1 Buffer get 1M resistors on the audio input's switch.
Could be useful do the same in B1Triode circuit to prevent thumps noise ?
Schematic source : Papa Watt
