Thank Prasi, the second value is amp (I) right ??Hello Hicoco,
If you use higher values in a 250W power amp, the power dissipation and voltage drop across R2, will increase tremendously. Following text gives the example.
R2,ohm..... Power,W ..... Del V R2
0.1 ..... 6.1 ..... 0.8
0.15 ..... 9.1 ..... 1.2
0.22 ..... 13.3 ..... 1.7
0.33 ..... 20.0 ..... 2.6
0.47 ..... 28.4 ..... 3.7
so if i understand right and i have under 6.1 amps i will not need resistor
second value is the power dissipated in R2 and third value is the voltage drop across R2. it shows that with 0.22 ohms, you will need a power rating of atleast 15 to 20 Watts.
Mr Prasi,
What is the price of one PS PCB Board?. I am from India
Hello,
you can visit diyaudiocart for domestic buys.
Analog Design - AD-CRC-PSU-PCB - High Quality Dual Rail Universal CRC PSU PCB
regards
prasi
i get it thankssecond value is the power dissipated in R2 and third value is the voltage drop across R2. it shows that with 0.22 ohms, you will need a power rating of atleast 15 to 20 Watts.
reading your question again, here is the answer.
if you have lower current demand from amp, then you can go for higher value of R2 and thus achieve lower psu ripple.
CRC configuration helps you to minimize psu ripple at the cost of loss of headroom and practically managing dissipation in R2 itself.
While lower ripple is desirable, it then becomes a question of managing dissipation in R2 and PSU voltage drop caused by R2.
I hope I have made things slightly clear.
regards
Prasi
regards
Prasi
Prasi, I just received it today!
Thank you very much, nice heavy duty PC boards.....I will send you a pm
thank you for your confirmation Hicoco. You are more than welcome to send me a PM / post here if you have any query or any other topic.
regards
Prasi
regards
Prasi
sthcoaster-2 nos. paid, shipped
MartinJaeger- 2 nos. paid, shipped
Amadeus00- 2 nos. paid, delivered
theoracle- 4 nos., paid, shipped
Hicoco- 2 nos, paid, delivered
Oracle1-2 nos. paid, delivered
Mituisho - 2 nos. booked, paid, to be shipped with 2 nos.baby huey's
Mravinsky - 4nos to be shipped with 4 nos. baby huey's
TS Lo - 2nos to be shipped with 2 nos. baby huey's
14 remaining
Thank you very much guys for confirmation of delivery.
14 remaining
theoracle- 4 nos., paid, delivered
Mobes123- 6 nos. PM sent.
8 remaining
Thank you theoracle for confirmation.
Prasi
8 remaining
Prasi
sthcoaster-2 nos. paid, delivered
Mituisho - 2 nos. booked, paid, shipped
14 remaining
Prasi
MartinJaeger please confirm the delivery
14 remaining
Prasi
Hi prasi,
I am confused, i will use MUR860G, do i need C3, C3', C4, C4', C5, C5', C6, C6'??
Hello Hicoco,
MUR860G is an ultrafast recovery diode. So if you are not using the CS, RS, C2 snubber, then use C3,C4,C5,C6.
On the other hand, if you had used MSR860G, which is a soft recovery diode, then there is no need to use C3, C4, C5, C6.
please refer the schematic.
regards
Prasi
regards
Prasi
I would like to purchase two boards.
A couple of years ago I purchased 4 United Chemicon EKMH350VQT563MB80T on a whim.
Despite whatever Mouser's website says, they have 5 leads and I can't find the specs in the data sheet (35V models stop at 22,000uf on the data sheet)- but am holding one in my hand - they do exist.
Spec's listed on the Mouser website are
56,000uf
35V
ESR 8 mOhms
Ripple Current 8.29 A
40mmx80mm
If you have any suggestions for building with these (or reason to NOT build with them😕).
Maybe something more robust than a CL-60 for mitigating power on thump.
If that's obscene for the capacitance, maybe dual mono PSU's with two transformers? When building dual mono would one half the transformer size - instead of a single 400VA, 2x 200VA?
Not sure what amp I'm going to build next, probably an M2, or F6,
56,000uf
35V
ESR 8 mOhms
40mmx80mm
- Group Buys
- CRC Power Supply (Class A amplifier)
