Zen -> Cen -> Sen, evolution of a minimalistic IV Converter
I have got 4x 2Sk146 which I want to use in the SEN topology. For the single channel I will use 2x PCM1704 in parallel. Since 2SK146 is two JFET in one aluminum enclosure I would like to ask how to connect two 2SK146 per channel (A or B from enclosed schematics to better cope with heat dissipation/alignment?
Thanks,
Bern
Thanks,
I've measured Idss of my JFETS (2SK146BL). The total of lower and upper pairs of Jfets are 20.6 and 20.7mA for the left channel and 20.62 and 20.72mA respectively for the right channel (see enclosed details). Do you think that 0.1mA Idss mismatch/difference could be an issue? If so how could I limit the adverse impact?
I've build two 10x3.6V (18650) 36V Li-ion battery. Theoretically fully charged single battery should give 42V DC. Do you think that such voltage will be safe for SEN?
TIA,
Bern
Will end up as a small DC at the current input.
Add a small degeneration resistor to the source of the higher current and trim the DC voltage to Zero at the current input.
Why would you need 36V ?
Have you calculate how much power you will dissipate, and what is the maximum rating for your FETs ?
Patrick
Patrick
I have spare, unused 36V batterry from other project which I would like to use in SEN. :)
I've read in the LA article:
"...you can go further to 27V or 36V if you wish. The benefit of higher voltage is lower JFET capacitances, which in turn means higher bandwidth and lower distortion."
Roughly I calculate the power of single JFET P=UxI so 36Vx0.01A=0.36W
so maybe for 4 fets should be 1,44W and 1,68W (with max 42V)
For single 2SK146 MAX Gate-Drain Voltage (VGDS) is -40V (as datasheet says) but in SEN schematics there are two Fets in paralell so I assume that I can use max 42V (correct me if I'm wrong).
Please have a look on schematic I added OPTIONAL resistors (gate stoppers and degenerate resistors). Is it correct?
I am going use SEN and 2xPCM1704 in parallel per channel.
Gentlemen (in general and no one in particular),
Many thanks for your interest over the many years; I am truely flattered.
While the SEN / CEN IV look deceptively simple, they are quite complicated to implement and requires good understanding of analogue electronics.
Above all, they require the use of floating power supplies and hence are suspectible to grounding and noise pick-up problems.
If you do not process such skills, I suggest you try something easier for beginners, such as the excellent ZEN IV by Nelson himself.
You will find a lot of details here :
Zen I/V Converter | Pass DIY
Zen I/V Converter
My apologies for not being able to nurse every individual projects to theri successful conclusion.
If you have a technical issue involving the circuit design that has not been addressed before, I am of course interested to know.
Patrick
JFET current drifts with temperature.
It will drift a lot less when degenerated a lot.
So e.g. if you use 2SK369V and degenrated to 1~2mA, it will be a lot more stable,
then e.g. a 2SK170GR used in the same way.
2Sk209BL or 2SK117BL would also be good choice.
Patrick
What is the recommendation for nulling the offset of a TDA1541 into the SEN where Iout from DAC is unipolor 0 to -4mA?
I've read from other threads using simple resistors 2K2 tied to +5v acting as ccs to source +2mA and using CCS from JFets.
With JFets, is it better to heavily degenerate i.e. 2SK170BL down to 2mA or a BF245A with measured IDSS of 2mA and use at IDSS with slight adjustment at source?
Please excuse the ignorance, I'm trying to understand the concept of which method yields better stability, thanks.
