The diyAudio First Watt M2x
I bought and await delivery of a quad set from 6L6's recommended source, thanks 6, i think. Another project, need to finish the F6 first, I think I have to do the M2 after reading several posts saying the M2 sounds better! It's all subjective of course, maybe the person with a counter top single speaker radio, who is satisfied with that, is the smart (or lucky) one!
If neg H2 is your goal, I suggest that this really isn't the amplifier for you. The current offering that is neg H2 beauty queen would be the ACA, ...
Perhaps so, but the M2X with Mountainview input stage and inverted speaker polarity connection also has the potential to be at least as nice with the advantage of higher power capability. I am still waiting for comments.
Hi angrypat I have built both the F6 and M2. My F6 has a 400VA supply and my M2 has 2x 300VA supply. Both are great amps in my system and I could easily live with either ( I also have hypex Ncore and PP and SE valve monoblocks to compare). I listen to more rock, funk, blues and prog than classic music and currently favor the F6. Maybe it is also because I bult it first and it gave me a lot of wow moments, where I got new insights into, by me, well known music. Im not stopping and will build a SissySIT and probably F2X (to try different buffers - as I already have the boards) and probably also Nelsons SIT once awailable through the store. We are the lucky ones as building is fun 😀
I have honestly been impressed with all the input stages and would he very hard pressed to have to choose a favorite.
+1
I find the M2X with its various alternative input stages to be a very (if not the most) versatile solution capable of delivering very high quality entertainment value to various needs. Let's hear more impressions from completed builds.🙂
Take the M2x idea of building the unity gain input stage on a field-swappable daughter card, and generalize it.
One possibility is to partition a power amplifier into "N" separate pieces; each piece represents one block in the power amp's block diagram. Now implement each of those pieces on a separate, field-swappable daughter card. Voila, mix-and-match power amps! Immerse your bewildered self in a swirling miasma of JFET LTPs, BJT LTPs, dueling banjo LTP quads, current mode operation, voltage mode operation, Miller compensation, Two Pole compensation, Output Inclusive compensation, Class A, Class G, Class AB, Thermal-Trak, unity gain output stages, Gain>1 output stages, interstage transformers, auto transformers, optical bias, sliding bias, microprocessor controlled bias, nuvistor tube voltage amplifying stages, folded cascode voltage amplifying stages, Rush cascode stages, Hawksford error correcting stages, current dumping stages.
I realize that the idea of swapping an output stage might seem needlessly radical. If you feel this way, imagine that only (N-1) pieces are on daughter cards, and the final piece, the output stage, is fixed. But I would remind you that quite a few 8.1 channel power amps for home theater uses, do indeed have swappable output stages. Everything including the heatsink, comes out.
Timid builders afflicted with "I dare not be the first to try something" paralysis, will have to sit and wait a good long time, before other non-paralyzed folks try each and every possible combination & publish their listening impressions for all to read. However, in exchange for waiting patiently, the timid are rewarded with a clear idea of what to try first: build the option that other people seem to prefer the most. I want what other people want. It's a conformist's dream come true. On the other hand, the non-timid, the brave trailblazers, are rewarded too. They create brand new listening experiences that nobody else has ever had. The joy of discovery! The thrill of exploring the unknown! A win-win for everyone.
M2x boards are in the Store and shipping to customers
On Monday Sept 10th I went to the diyAudio store website and placed an order for an M2x board set. They were delivered at noon today, Wednesday Sept 12th. The boards were nicely packaged, well protected, and the PCB manufacturing work appears to be very high quality, photo below. Congratulations to the team!
_
_
They look fantastic!!! I'm drooling over here!
(I have to admit that the Austin board looks intimidating! 😱 )
One day I'll build the M2x... one day! Thanks for the pic.
Rafa.
And by the same token, the Tucson board looks small and simple and quick and the very opposite of intimidating.
True story: 6L6 completely assembled and soldered one of his Tucson boards in 120 seconds while he was talking to me on Face Time. I saw him do it. And the board worked flawlessly -- he's listening to it right now.
That's a great price too. I paid $10 more over 5 months ago for a matched set. Originally bought them for an F5 but held off and kept them for the M2x. I'm tempted to buy another set so I can stuff my F5 boards as well. Decisions decisions.
... Decisions decisions.
I'd suggest finishing your M2X first, it is very versatile. Mark Johnson made sure that each of the multiple input stages has unique merit and signature. Remember to evaluate and listen to both normal and reversed speaker polarity with each input stage. Most probably your need will be fully met. You may satisfy your curiosity later, perhaps by building the F5 or F7 (it is current production but you can build something from the info on the F7 thread or wait for the time it is officially released for DIY).
