recapping using caps with much higher voltage value range compared to original specs
And that's why you must ensure that your replacement capacitors are as snug as a bug in a rug!
:vampire3:Elna those pathological tricky liars they trick the masses into thinking silk have an effect on sound ...what a liars they are !!. I have technical prof learned in university that those silk scammers are liars and nothing but liars🙄they make those caps so big that they look like silk grenades
Ok now seriously ....let's buy some Silmics
robert2017 said:
And the hearing test was blind and the difference was night and day .
Double-blind is better. After night and day we expect even the wife in the kitchen heard the difference?
Let us be completely clear about something: if there really was an audible difference between two non-faulty caps of the same value (you did check the exact value?) and the same technology then it would be a small difference - assuming that the value and technology were appropriate to that circuit position. Never night and day. Night and day is the difference between two caps of different values, or one is faulty, or both are inappropriate to that circuit position.
Be aware that physically large caps (and many 'audio' caps are large, although not all) have larger stray capacitance and interference pickup so some degradation in circuit performance may be heard, but misunderstood as an an improvement.
The BIG BIG problem with the science is that if the science can't explain something the science conclude that thing don't exist.
I guess you have never met a scientist?
robert2017 said:
For a loser technical knowledge and experience means he thinks he know anything but the loser don't even have true speakers and a treated room so actually his believes are based mostly on theory and classical science .
Be aware that describing someone who disagrees with you as a "loser" is getting dangerously close to behaviour which may cause a Moderator to feel your collar.
For a winner like me
Bragging is not against forum rules but merely sends a different signal than the one presumably intended.
So a board cooper trace that have 40cm and in which are connected 40 components will not create inductance ?. If we take into consideration that all the traces inside of an amp are measuring 10s and 10s of meters I must be punished because of 2,5 cm ?
Loop area is what matters, not length. But of course, you already knew this and was about to say so.
Personally, I think Silmics lack the all elusive and often ignored aspect of sound quality... hyperbole.
Black Gates have true dementonal hyperbole! In the highs and lows.😱
I don't think we're going to hear back from him or see those speakers, pity.
Well, I'm off to rearrange the magic crystals on my amp and move the pyramids from one speaker to the other. There are forces at work beyond our comprehension. Powerful, scary forces! (Science can't explain).
Be sure to observe proper safety precautions. Approved gloves, face shield and hearing protection when you move those crystals. 4' long tongs are a good idea also. Of course a fire extinguisher should always be on hand when using such powerful stuff.
Pity. This could have been a really good thread about capacitor's accepted physical behavior... 🙁
But childish behavior (from both parts, I dare to say) made the conversation to deviate from its more noble potential goals... 😱
A pity also that most conversations about this kind of topic suffers the same destiny.
And we are supposes to be intelligent grown up man (or women; or both 😀)
M.
Hi robert2017,
As others have suggested earlier, I'm thinking you are way out of your depth here.
Anyway, you aren't here to learn, and you will not accept the help that has been offered. I'm out of here, it is a waste of time trying to communicate with you on these matters, and you are acting as a troll even if you don't intend to.
-Chris
He wasn't interested in learning or accepting help on this thread either:
I damaged my Technics SU-3500 amp
Winners also connect their main power caps the wrong way round apparently.. Jus' saying..
