Gurpreet 22g kidda paji the jallander to ho 22g aap kol apex sr200 da lay file hai
Hello Sunny,I really love conversation in local language but not in forum only in PM. Please don't mind 🙂. By the way go on post no. #1520 by Sonal Kumar
Studio Reference Amplifier
PCB design by Mr. Alex MM little modified by Sonal kumar. Maybe Alex MM help you for this pcb.
Gurpreet Singh
AX14 BOM Reference
Yes. To the best of my knowledge, illustrious Prasi posted the most recent on 8 Aug 2018.
AX14 BOM by Prasi
Ben Franklin
Anybody have the BOM from ax14?
AX14 BOM by Prasi
Ben Franklin
AX14 BOM by Prasi
Ben Franklin
its not working. Cant open it with notepad
Like trying to eat soup with a fork.😀its not working. Cant open it with notepad
It is necessary to first unpack the archive and then to read the file an Excel spreadsheet.
Okay so iahve a little problem the ax14 is a mono amplifier right? How can i make it stereo? what is the pcb for that
Build 2 of them pcbs and you will have stereo. Read through the thread on how people have built different amps.
Prasi
Prasi
Hello.Any opamp based schematic of a signal audio splitter ? i want to give the same signal to two different amplifiers.
Hello mouna,
some thing like this would work?
regards
Pasi
R4 and R7 should be at the output of C4 and C5. But most decent preamplifiers will drive several power amps in parallel, so you won't need any spliters.
Agree. A good quality opamp can drive 4-6 output easily...
Sajti
Mr. Prasy, I was also looking for a splitter but for four amplifiers. I would like it if you have a PCB design for four. Thank you.
See if this is useful to you, not tested. Although do read comments posted by sajti/ivanlukik.
regards
Prasi
- 100W Ultimate Fidelity Amplifier
